Aller au contenu principal
Disassembling Home Stereo and Theater Philips MCD288
Ce dont vous avez besoin
  1. Disassembling Home Stereo and Theater Philips MCD288, Undo screws: étape 1, image 1 de 1
    • remove the 4 screws on the bottem of the main set
  2. Disassembling Home Stereo and Theater Philips MCD288, Expose main latches: étape 2, image 1 de 1
    • Lift the aluminium pane at both sides with a spudger.
  3. Disassembling Home Stereo and Theater Philips MCD288, Start with the bottom edges: étape 3, image 1 de 1
    • To lift an edge, shift the front part at that edge towards the side while bending both parts apart (picture of the inside at step 5)
    • hint: Start at the bottom, then continue with the sides according to step 4, because the bottom is only fastened by the screws of step 1, while the top has 3 extra latches (seen in step 5).
  4. Disassembling Home Stereo and Theater Philips MCD288, Losen main latches: étape 4, image 1 de 2 Disassembling Home Stereo and Theater Philips MCD288, Losen main latches: étape 4, image 2 de 2
    • To detach the sides, pull a main latch towards you and keep on lifting the top part further.
    • repeat for three latches on each side.
  5. Disassembling Home Stereo and Theater Philips MCD288, The inside: étape 5, image 1 de 2 Disassembling Home Stereo and Theater Philips MCD288, The inside: étape 5, image 2 de 2
    • These pictures show the latches on each edge and on the top of the set.
2 autres ont terminé cette réparation.
Philipp
Membre depuis le 03/16/15
71 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 26
30 derniers jours : 63
Total : 7,362
