Introduction
This introduction shows how to open the main set of a Philips MCD288/??. It should be the same for all /??s. The front panel might get buckled a bit.
Ce dont vous avez besoin
To lift an edge, shift the front part at that edge towards the side while bending both parts apart (picture of the inside at step 5)
hint: Start at the bottom, then continue with the sides according to step 4, because the bottom is only fastened by the screws of step 1, while the top has 3 extra latches (seen in step 5).
To detach the sides, pull a main latch towards you and keep on lifting the top part further.
repeat for three latches on each side.
2 autres ont terminé cette réparation.
