Aller au contenu principal
Disassembling IBM ThinkPad A30 Floppy Disk Drive
  1. Disassembling IBM ThinkPad A30 Floppy Disk Drive, Battery: étape 1, image 1 de 2 Disassembling IBM ThinkPad A30 Floppy Disk Drive, Battery: étape 1, image 2 de 2
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
  2. Disassembling IBM ThinkPad A30 Floppy Disk Drive, Floppy Disk Drive: étape 2, image 1 de 2 Disassembling IBM ThinkPad A30 Floppy Disk Drive, Floppy Disk Drive: étape 2, image 2 de 2
    • Hold the Thinkpad as the picture shows.
    • There is a switch located just above and to the right of the drive.
    • Slide the switch to the right. A small, black tab will pop out.
  3. Disassembling IBM ThinkPad A30 Floppy Disk Drive: étape 3, image 1 de 2 Disassembling IBM ThinkPad A30 Floppy Disk Drive: étape 3, image 2 de 2
    • Pull the small black tab away from the computer to access the drive.
    • Gently pull the drive out from the laptop.
    • If there is a problem with your tab, whether it doesn't pop out or it doesn't expose the floppy drive, please check the corresponding entry in the troubleshooting page.
To reassemble, place the floppy disk drive back into its bay the way it was facing before
Jessica
Membre depuis le 10/06/10
162 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 4-44, Amido Fall 2010 Membre de l'équipe Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 membres
26 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 2,633
