Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Pièces
Aucune pièce spécifiée.
  1. Flip the ThinkPad over so that it is upside down. Slide the highlighted tab to the left.
    • Flip the ThinkPad over so that it is upside down.
    • Slide the highlighted tab to the left.
    • With your finger on the tab, remove the battery by lifting it upwards away from the laptop.
  2. Remove the two 5.3mm cover screws. Gently lift the cover.
    • Remove the two 5.3mm cover screws.
    • Gently lift the cover.
  3. Remove the four 9.1mm screws attached to the ethernet and modem cards.
    • Remove the four 9.1mm screws attached to the ethernet and modem cards.
  4. When lifting the cards, be careful not to rip out the cables! Gently lift the modem and ethernet cards. Remove the cables that attach the modem and ethernet cards.
    • When lifting the cards, be careful not to rip out the cables!
    • Gently lift the modem and ethernet cards.
    • Remove the cables that attach the modem and ethernet cards.
Alan
Membre depuis le 07/10/2010
380 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 4-44, Amido Fall 2010 Membre de l'équipe Cal Poly, Team 4-44, Amido Fall 2010
CPSU-AMIDO-F10S4G44
4 membres
26 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 1,735
