Aller au contenu principal
Disassembling KDDI Kyocera A5521K Logic Board
Ce dont vous avez besoin
  1. Disassembling KDDI Kyocera A5521K Logic Board, Disassembling KDDI Kyocera A5521K Battery: étape 1, image 1 de 3 Disassembling KDDI Kyocera A5521K Logic Board, Disassembling KDDI Kyocera A5521K Battery: étape 1, image 2 de 3 Disassembling KDDI Kyocera A5521K Logic Board, Disassembling KDDI Kyocera A5521K Battery: étape 1, image 3 de 3
    • Turn the phone over to expose the battery cover.
    • Apply pressure to the back of the battery cover to slide it down.
    • The battery cover is now separate from the phone.
  2. Disassembling KDDI Kyocera A5521K Logic Board: étape 2, image 1 de 3 Disassembling KDDI Kyocera A5521K Logic Board: étape 2, image 2 de 3 Disassembling KDDI Kyocera A5521K Logic Board: étape 2, image 3 de 3
    • Remove the battery by pushing it up and out from the bottom.
    • The battery, cover, and phone should now be separated.
  3. Disassembling KDDI Kyocera A5521K Logic Board, Back Plate: étape 3, image 1 de 2 Disassembling KDDI Kyocera A5521K Logic Board, Back Plate: étape 3, image 2 de 2
    • Remove the four screws with the Y0 screwdriver.
  4. Disassembling KDDI Kyocera A5521K Logic Board: étape 4, image 1 de 2 Disassembling KDDI Kyocera A5521K Logic Board: étape 4, image 2 de 2
    • Remove the black, rubber screw caps towards the top of the back of the phone to reveal two additional screws.
    • Remove the two screws with a Y0 screwdriver.
  5. Disassembling KDDI Kyocera A5521K Logic Board: étape 5, image 1 de 3 Disassembling KDDI Kyocera A5521K Logic Board: étape 5, image 2 de 3 Disassembling KDDI Kyocera A5521K Logic Board: étape 5, image 3 de 3
    • Rotate the phone 180 degrees.
    • Carefully separate the back plate from the remainder of the phone.
    • The back plate should now be detached from the rest of the phone.
  6. Disassembling KDDI Kyocera A5521K Logic Board, SD Card Slot: étape 6, image 1 de 3 Disassembling KDDI Kyocera A5521K Logic Board, SD Card Slot: étape 6, image 2 de 3 Disassembling KDDI Kyocera A5521K Logic Board, SD Card Slot: étape 6, image 3 de 3
    • Rotate the phone approximately 45 degrees to the right.
    • Gently pry up the SD card slot with a spudger.
  7. Disassembling KDDI Kyocera A5521K Logic Board, Logic Board: étape 7, image 1 de 3 Disassembling KDDI Kyocera A5521K Logic Board, Logic Board: étape 7, image 2 de 3 Disassembling KDDI Kyocera A5521K Logic Board, Logic Board: étape 7, image 3 de 3
    • Lift up on the first connection shown using a pair of pliers.
    • Disconnect the first connection between the logic board and the wire using the pair of pliers.
  8. Disassembling KDDI Kyocera A5521K Logic Board: étape 8, image 1 de 3 Disassembling KDDI Kyocera A5521K Logic Board: étape 8, image 2 de 3 Disassembling KDDI Kyocera A5521K Logic Board: étape 8, image 3 de 3
    • Repeat the above steps for the second connection.
    • Use the pliers to pry up the connection.
    • Use the pliers to disconnect the connection between the logic board and the wire.
  9. Disassembling KDDI Kyocera A5521K Logic Board: étape 9, image 1 de 1
    • Lift up on the bottom of the logic board with a spudger.
    • Gently remove the rest of the logic board from the phone.
  10. Disassembling KDDI Kyocera A5521K Logic Board: étape 10, image 1 de 2 Disassembling KDDI Kyocera A5521K Logic Board: étape 10, image 2 de 2
    • The logic board should now be completely disconnected from the phone.
Dominic Grisafe
Membre depuis le 04/15/10
157 Réputation
10 tutoriels rédigés
Équipe
Cal Poly, Team 28-25, Regan Spring 2010 Membre de l'équipe Cal Poly, Team 28-25, Regan Spring 2010
CPSU-REGAN-S10S28G25
4 membres
20 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 1,775
