Introduction
This guide will show how to remove the front panel of the from the rest of the radio. This is useful when the front panel needs to be serviced, or to enable the radio to be further disassembled. This guide will remove a number of small pieces of hardware (screws and nuts). Be sure to have containers on hand to store them in so they do not get lost.
Ce dont vous avez besoin
Push down on the tab that locks the power connection together, and slide the two connectors apart.
Unscrew the antenna downlead from the antenna pigtail coming out of the radio, and pull the two apart.
Unscrew the microphone connector from the front panel of the radio, and pull it out.
There are two tabs that sit underneath the sides of the face plate. They have a tendency to break out the plastic over top of them while removing the covers. To help prevent this, push inward on the side of the cover, just behind the face plate as you take off the covers.
Lift up on the rear of the top cover, and slide it towards the back of the radio to disengage the three tabs at the front.
Repeat for the bottom cover of the radio.
On the left side of the screen, gently pull on the tuning knob, separating it from the radio.
The upper knob on the right is the volume. Gently pull it away from the radio to remove it.
The lower knob on the right is the squelch knob. Remove it in the same way as the other two knobs.
Set the three knobs aside, so they can be put back on later.
