Aller au contenu principal
Disassembling Kinivo ZX100 Mini Portable Speaker
Conditions préalables uniquement
Ce tutoriel est uniquement destiné à être utilisé comme prérequis d'autres tutoriels. Il ne se suffit pas à lui-même.
Ce dont vous avez besoin
  1. Disassembling Kinivo ZX100 Mini Portable Speaker, Disassembling Kinivo ZX100 Mini Portable Speaker: étape 1, image 1 de 1
    • Open the circular portion at the top of the speaker by twisting it until it reaches the maximum possible height.
    • Make sure it is twisted fully, as this will allow access to four screws to be removed in the next step.
  2. Disassembling Kinivo ZX100 Mini Portable Speaker: étape 2, image 1 de 2 Disassembling Kinivo ZX100 Mini Portable Speaker: étape 2, image 2 de 2
    • Remove the four 12 mm Phillips screws from the enclosure.
  3. Disassembling Kinivo ZX100 Mini Portable Speaker: étape 3, image 1 de 2 Disassembling Kinivo ZX100 Mini Portable Speaker: étape 3, image 2 de 2
    • Separate the resonator portion from the base of device to reveal the middle separator of the enclosure. The enclosure will now be in two pieces.
    • Hold the resonator portion of the enclosure gently aside to make sure there is no tension on the black and red wires coming from the bottom portion of the device.
    • Excessive force may disconnect the black and red speaker wires from the circuitry in the bottom portion of the device.
  4. Disassembling Kinivo ZX100 Mini Portable Speaker: étape 4, image 1 de 1
    • Separate the very bottom portion of the enclosure (marked in red) by pulling vertically on the red portion of the enclosure (marked in orange).
    • Gently set the very bottom portion and the resonator section aside once they have both been separated.
    • Remove the circuit board with your hands by lifting and sliding the board away from the LED indicator.
2 autres ont terminé cette réparation.
Laura Dion
Membre depuis le 03/26/15
143 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 1-5, Shastany Spring 2015 Membre de l'équipe UMass Dartmouth, Team 1-5, Shastany Spring 2015
UMASSD-SHASTANY-S15S1G5
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 8
Total : 97
