Aller au contenu principal
Disassembling Kodak Advantix F350 Back Cover
Ce dont vous avez besoin
  1. Disassembling Kodak Advantix F350 Back Cover, Back Cover: étape 1, image 1 de 1
    • Turn off the camera.
    • Locate the power switch on the front of the camera below the camera lens.
    • Slide the switch to the off position.
  2. Disassembling Kodak Advantix F350 Back Cover: étape 2, image 1 de 2 Disassembling Kodak Advantix F350 Back Cover: étape 2, image 2 de 2
    • Locate the 3 screws that hold the back cover to the camera.
    • One screw is located on the film opener side of the camera.
    • The other screws are located on the opposite side of the camera.
  3. Disassembling Kodak Advantix F350 Back Cover: étape 3, image 1 de 3 Disassembling Kodak Advantix F350 Back Cover: étape 3, image 2 de 3 Disassembling Kodak Advantix F350 Back Cover: étape 3, image 3 de 3
    • Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover.
  4. Disassembling Kodak Advantix F350 Back Cover: étape 4, image 1 de 2 Disassembling Kodak Advantix F350 Back Cover: étape 4, image 2 de 2
    • Open the film door to remove the back cover.
    • Slide the film door lever to the left until the film door opens.
  5. Disassembling Kodak Advantix F350 Back Cover: étape 5, image 1 de 2 Disassembling Kodak Advantix F350 Back Cover: étape 5, image 2 de 2
    • Use a plastic opening tool to pry the case open until a small gap is present.
    • Repeat this process at the top and bottom of the film door to loosen it.
  6. Disassembling Kodak Advantix F350 Back Cover: étape 6, image 1 de 3 Disassembling Kodak Advantix F350 Back Cover: étape 6, image 2 de 3 Disassembling Kodak Advantix F350 Back Cover: étape 6, image 3 de 3
    • Grab the top and bottom of the case firmly as shown.
    • Gently remove the back of the camera case with a slight twisting motion.
David Cottrell
Membre depuis le 10/04/11
88 Réputation
5 tutoriels rédigés
Équipe
UW Stout, Team 1-2, Zhou Fall 2011 Membre de l'équipe UW Stout, Team 1-2, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G2
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 1,080
