Aller au contenu principal
Disassembling Kodak Advantix F350 Display
Ce dont vous avez besoin
  1. Disassembling Kodak Advantix F350 Display, Back Cover: étape 1, image 1 de 1
    • Turn off the camera.
    • Locate the power switch on the front of the camera below the camera lens.
    • Slide the switch to the off position.
  2. Disassembling Kodak Advantix F350 Display: étape 2, image 1 de 2 Disassembling Kodak Advantix F350 Display: étape 2, image 2 de 2
    • Locate the 3 screws that hold the back cover to the camera.
    • One screw is located on the film opener side of the camera.
    • The other screws are located on the opposite side of the camera.
  3. Disassembling Kodak Advantix F350 Display: étape 3, image 1 de 3 Disassembling Kodak Advantix F350 Display: étape 3, image 2 de 3 Disassembling Kodak Advantix F350 Display: étape 3, image 3 de 3
    • Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover.
  4. Disassembling Kodak Advantix F350 Display: étape 4, image 1 de 2 Disassembling Kodak Advantix F350 Display: étape 4, image 2 de 2
    • Open the film door to remove the back cover.
    • Slide the film door lever to the left until the film door opens.
  5. Disassembling Kodak Advantix F350 Display: étape 5, image 1 de 2 Disassembling Kodak Advantix F350 Display: étape 5, image 2 de 2
    • Use a plastic opening tool to pry the case open until a small gap is present.
    • Repeat this process at the top and bottom of the film door to loosen it.
  6. Disassembling Kodak Advantix F350 Display: étape 6, image 1 de 3 Disassembling Kodak Advantix F350 Display: étape 6, image 2 de 3 Disassembling Kodak Advantix F350 Display: étape 6, image 3 de 3
    • Grab the top and bottom of the case firmly as shown.
    • Gently remove the back of the camera case with a slight twisting motion.
  7. Disassembling Kodak Advantix F350 Display, Front Cover: étape 7, image 1 de 2 Disassembling Kodak Advantix F350 Display, Front Cover: étape 7, image 2 de 2
    • Locate the 3 screws on the camera that hold the front cover of the camera to the camera body.
    • The first 2 are located on the bottom of the camera.
    • The last screw is located behind the flash module.
    • Turn the camera on, and raise the flash module to locate the flash module screw.
  8. Disassembling Kodak Advantix F350 Display: étape 8, image 1 de 2 Disassembling Kodak Advantix F350 Display: étape 8, image 2 de 2
    • Remove the 2 screws at the base of the camera housing.
    • Use the Phillips #00 Precision Screwdriver and remove the screws.
    • Repeat this process for the screw behind the flash module.
  9. Disassembling Kodak Advantix F350 Display: étape 9, image 1 de 2 Disassembling Kodak Advantix F350 Display: étape 9, image 2 de 2
    • Remove the screw located under the flash module using the Phillips #00 Precision Screwdriver.
  10. Disassembling Kodak Advantix F350 Display: étape 10, image 1 de 2 Disassembling Kodak Advantix F350 Display: étape 10, image 2 de 2
    • Remove the flash cover.
    • Remove the flash module by twisting it up and outward of the camera housing.
    • The cover can now be be removed.
  11. Disassembling Kodak Advantix F350 Display: étape 11, image 1 de 2 Disassembling Kodak Advantix F350 Display: étape 11, image 2 de 2
    • Remove the film door lever.
    • Remove the screw holding the film lever in place by using a Phillips #00 Precision Screwdriver.
    • Using a plastic opening tool, gently pry the switch upwards to remove it.
  12. Disassembling Kodak Advantix F350 Display: étape 12, image 1 de 1
    • Open the battery door by pushing the lever towards the arrow indicated.
  13. Disassembling Kodak Advantix F350 Display: étape 13, image 1 de 3 Disassembling Kodak Advantix F350 Display: étape 13, image 2 de 3 Disassembling Kodak Advantix F350 Display: étape 13, image 3 de 3
    • Remove the front cover.
    • Insert your thumb in the film hole and gently pry the bottom loose.
    • Once the front is loose, gently pull it out.
  14. Disassembling Kodak Advantix F350 Display, Display: étape 14, image 1 de 1
    • Locate the 3 screws on the top of the camera.
    • These will be removed in the next step.
  15. Disassembling Kodak Advantix F350 Display: étape 15, image 1 de 3 Disassembling Kodak Advantix F350 Display: étape 15, image 2 de 3 Disassembling Kodak Advantix F350 Display: étape 15, image 3 de 3
    • Remove the 3 screws using the Phillips #00 Precision Screwdriver.
  16. Disassembling Kodak Advantix F350 Display: étape 16, image 1 de 2 Disassembling Kodak Advantix F350 Display: étape 16, image 2 de 2
    • Remove the LCD.
    • Gently pry the LCD and plastic bezel upward with a plastic opening tool.
    • Remove LCD and replace as needed.
David Cottrell
Membre depuis le 10/04/11
88 Réputation
5 tutoriels rédigés
Équipe
UW Stout, Team 1-2, Zhou Fall 2011 Membre de l'équipe UW Stout, Team 1-2, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G2
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 11
Total : 1,076
