Aller au contenu principal
Disassembling Krups 963 Top Cover
Ce dont vous avez besoin
  1. Disassembling Krups 963 Top Cover, Removing Bottom Screws: étape 1, image 1 de 1
    • Make sure the device is unplugged before continuing.
    • Use a Phillips size 2 screwdriver to remove the four 12mm screws found on the bottom of the machine.
  2. Disassembling Krups 963 Top Cover: étape 2, image 1 de 1
    • Remove the single black Phillips size 0 10mm length screw on the back of the machine.
  3. Disassembling Krups 963 Top Cover: étape 3, image 1 de 1
    • Remove the bottom cover from the machine and slide it down the power cord.
  4. Disassembling Krups 963 Top Cover, Disassembling Krups 963 Top Cover: étape 4, image 1 de 1
    • Remove the three 60mm Phillips size 0 screws holding the top cover on.
  5. Disassembling Krups 963 Top Cover: étape 5, image 1 de 1
    • Remove the top cap of the machine by turning it in a counter-clockwise motion (left hand in the picture), Check inside the water chamber, and if the silicone washer is inside, having fallen from the underside of the lid, retrieve it and reattach to the lid.
    • Remove the entire pressure valve stem that is attached to the side of the espresso machine: using a crescent wrench, turn the six-sided stem tube counter-clockwise; you'll find it best to apply the wrench as close to the wall of the espresso machine (farthest away from the right hand shown in the photo).
  6. Disassembling Krups 963 Top Cover: étape 6, image 1 de 1
    • Remove the grey plastic ring from the rim of the filter basket holder.
  7. Disassembling Krups 963 Top Cover: étape 7, image 1 de 1
    • Lift and remove the top black plastic cover from the machine.
3 autres ont terminé cette réparation.
Wyatt Hall
Membre depuis le 10/13/14
842 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 6-25, Maness Fall 2014 Membre de l'équipe Cal Poly, Team 6-25, Maness Fall 2014
CPSU-MANESS-F14S6G25
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 7
30 derniers jours : 21
Total : 3,456
