Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
Steps to remove LG VX8500 case
  1. Slide the battery release up.
    • Slide the battery release up.
  2. Remove the battery by lifting away from the case.
    • Remove the battery by lifting away from the case.
  3. Remove the 2 screw covers next to the rear speaker with a Push Pin.
    • Remove the 2 screw covers next to the rear speaker with a Push Pin.
  4. Remove the 4 cover screws with a Philips #00 screwdriver.
    • Remove the 4 cover screws with a Philips #00 screwdriver.
  5. Use the iPod opening tool to pry off the back casing.
    • Use the iPod opening tool to pry off the back casing.
  6. Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
    • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
  7. Separate the casing halves.
    • Separate the casing halves.
    • Be sure to keep track of the side buttons as they fall out.
Nathan Jones
Membre depuis le 10/04/2010
89 Réputation
10 tutoriels rédigés
Équipe
Cal Poly, Team 34-55, Forte Spring 2010 Membre de l'équipe Cal Poly, Team 34-55, Forte Spring 2010
CPSU-FORTE-S10S34G55
5 membres
20 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 3,312
