Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
Most of the screws that you will be removing are threaded into plastic; be careful when reinstalling screws as they can be easily cross threaded or break the plastic.
  1. Remove the six gray 25mm hex screws with a 4mm allen wrench.
    • Remove the six gray 25mm hex screws with a 4mm allen wrench.
    • Watch out when you lift the wheel up, as there are fragile wires connected to the bottom side.
    • Carefully lift up the wheel, but do not disconnect it from the rest of the device.
  2. Carefully lift the wheel off of the hub, exposing the 2 shifter paddle wires and PCB board.
    • Carefully lift the wheel off of the hub, exposing the 2 shifter paddle wires and PCB board.
  3. Remove the two 7.5 mm silver screws holding the green PCB board in the wheel with a Phillips #1 screwdriver.
    • Remove the two 7.5 mm silver screws holding the green PCB board in the wheel with a Phillips #1 screwdriver.
  4. Carefully remove the PCB board from the wheel hub.
    • Carefully remove the PCB board from the wheel hub.
  5. Carefully pinch and unplug the large 7-pin connector under the PCB board.
    • Carefully pinch and unplug the large 7-pin connector under the PCB board.
    • Be careful when unplugging this adapter, try not to pull on the wires to avoid damaging them. Instead, wiggle around the plastic connector while pulling on it to loosen it.
  6. You can now fully remove the wheel from the hub. Set it aside until you put the wheel back together.
    • You can now fully remove the wheel from the hub. Set it aside until you put the wheel back together.
    • Remove the innermost three 37.5mm silver screws with a Phillips #1 screwdriver.
    • Remove the wheel hub and push the connector through the center of the hub.
  7. The wheel hub can now be set aside and flip over the steering wheel housing to  reveal the under side.
    • The wheel hub can now be set aside and flip over the steering wheel housing to reveal the under side.
    • Remove the eight 15.9mm silver surrounding screws underneath the wheel housing with a Phillips #1 screwdriver.
  8. Rotate the housing back over and remove the top half of the housing revealing the majority of the components of the wheel.
    • Rotate the housing back over and remove the top half of the housing revealing the majority of the components of the wheel.
    • The housing cover can be set aside until you put the wheel back together.
  9. Remove the four 7.3mm silver screws attaching the green PCB board to the motor housing with a Phillips #1 screwdriver.
    • Remove the four 7.3mm silver screws attaching the green PCB board to the motor housing with a Phillips #1 screwdriver.
  10. Unplug the three plastic connectors on the left side of the PCB board.
    • Unplug the three plastic connectors on the left side of the PCB board.
    • Unplug the two plastic connectors on the top of the PCB board.
    • Unplug the three plastic connectors on the right side of the PCB board.
    • Pulling the plastic connectors requires a lot of force, but be careful and don't pull directly on the wires. Try to wedge or push the male side of the connector out.
    • If you need some extra leverage when removing these connectors, try using a plastic opening tool to pry off the connectors.
    • Removing these connectors allows easier access to the four screws attaching the PCB board mount to the motor housing.
  11. Remove the PCB board after all of the plastic connectors are disconnected.
    • Remove the PCB board after all of the plastic connectors are disconnected.
    • You can now set it aside.
  12. Remove the two 12.3mm upper black screws with a Phillips #2 screwdriver.
    • Remove the two 12.3mm upper black screws with a Phillips #2 screwdriver.
    • Remove the two 15.5mm bottom silver screws with a Phillips #1 screwdriver.
  13. Remove the PCB board mount and remove the clear plastic piece underneath. Set them aside until you reassemble the wheel.
    • Remove the PCB board mount and remove the clear plastic piece underneath.
    • Set them aside until you reassemble the wheel.
5 autre(s) ont terminé cette réparation.
Nicholas Gholdoian
Membre depuis le 21/04/2015
808 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 15-4, Amido Spring 2015 Membre de l'équipe Cal Poly, Team 15-4, Amido Spring 2015
CPSU-AMIDO-S15S15G4
4 membres
12 tutoriels rédigés
Hi - help please. I disassembled my G27 and a 2 inch long semicircular metal clip fell out during the process. I don’t know what it is or where it came from.
tony davies - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 2
7 derniers jours : 5
30 derniers jours : 36
Total : 2,236
