Aller au contenu principal
Introduction
This guide shows how to disassemble and remove the scroll wheel of the Logitech MBJ58 optical scroll mouse. This might be necessary if the wheel is stuck, difficult to turn, or dislodged. If it becomes dislodged, it can cause additional damage to the mouse’s motherboard, which is located beneath the wheel.
The scroll wheel may become jammed if the support spring that holds it in place is dislodged. To see how to repair that, as well as how to deconstruct other parts of the mouse, see the Logitech MBJ58 mouse troubleshooting guide.
Pièces
Aucune pièce spécifiée.
  1. Hold the mouse so that the bottom is facing up.
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
  2. Place the mouse so that the bottom is resting against a hard surface. Lift the top cover of the mouse gently, and remove it.
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
  3. Locate the scroll wheel on the mouse. Grab the scroll wheel with your thumb and index finger. Gently lift up, to remove the scroll wheel from the mouse.
    • Locate the scroll wheel on the mouse.
    • Grab the scroll wheel with your thumb and index finger.
    • Gently lift up, to remove the scroll wheel from the mouse.
  4. Locate the spring on the scroll wheel, and carefully remove the spring. Locate the spring on the scroll wheel, and carefully remove the spring.
    • Locate the spring on the scroll wheel, and carefully remove the spring.
  5. Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down. Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
    • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
  6. Use the images to locate where the resistance spring is. This spring will easily fall off. Grab the scroll wheel and its mount and gently pull them apart.
    • Use the images to locate where the resistance spring is.
    • This spring will easily fall off.
    • Grab the scroll wheel and its mount and gently pull them apart.
14 autres ont terminé cette réparation.
Maximilian Betkowski
Membre depuis le 11/01/2013
235 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 5-14, Forte Winter 2013 Membre de l'équipe Cal Poly, Team 5-14, Forte Winter 2013
CPSU-FORTE-W13S5G14
5 membres
14 tutoriels rédigés
7 commentaires
Excellent! I took an MBJ58 apart to remove accumulated gunk, and the resistance spring jumped onto my worktable before I noticed where it came from. Thanks for the help, well done!
Marty Swartz - Réponse
Heh, me too. Couldn't for the life of me figure out how it went back in. Thanks for the guide!
Steve Bennett - Réponse
Same thing happened to me...saved me a trip to the store for a new mouse!!
thanks for taking the time to post these photos!
Bill McFarland - Réponse
huh, thank you very much, amazing guide, the only for this product in Internet , and amazingly accurate
leartzajmi - Réponse
the resistence spring falled off on mine how do i out it back on help
Tay Carr - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 37
Total : 5,818
