Aller au contenu principal
Disassembling Marshall MS-2 Partner Circuit Board
Ce dont vous avez besoin
  1. Disassembling Marshall MS-2 Partner Circuit Board, Disassembling Marshall MS-2 Micro Amp Case Disassembly: étape 1, image 1 de 1
    • First be sure to turn the power switch to the off position.
    • Do this by turning the leftmost knob counter-clockwise as until the line points to "off."
  2. Disassembling Marshall MS-2 Partner Circuit Board: étape 2, image 1 de 3 Disassembling Marshall MS-2 Partner Circuit Board: étape 2, image 2 de 3 Disassembling Marshall MS-2 Partner Circuit Board: étape 2, image 3 de 3
    • Now remove the battery.
    • On the back of the device locate the battery cover.
    • Remove it by pushing down on the clip.
    • Then pull the piece of fabric until the battery comes out.
  3. Disassembling Marshall MS-2 Partner Circuit Board: étape 3, image 1 de 2 Disassembling Marshall MS-2 Partner Circuit Board: étape 3, image 2 de 2
    • Use the long, skinny phillips head screwdriver to remove the 4 7/16" screws on the back of the device in the four corners.
    • Once unscrewed, do not try to take each screw out. Move to next step once all screwed have been unscrewed.
  4. Disassembling Marshall MS-2 Partner Circuit Board: étape 4, image 1 de 1
    • Now pull the back panel off and place it down as shown. Pull the panel straight up so you do not lose the screws.
  5. Disassembling Marshall MS-2 Partner Circuit Board, Partner Circuit Board: étape 5, image 1 de 2 Disassembling Marshall MS-2 Partner Circuit Board, Partner Circuit Board: étape 5, image 2 de 2
    • Use a 9/16" socket to remove the nut around the headphone jack. Be careful to not lose the washer.
  6. Disassembling Marshall MS-2 Partner Circuit Board: étape 6, image 1 de 1
    • Remove the 7/16" phillips head screw.
  7. Disassembling Marshall MS-2 Partner Circuit Board: étape 7, image 1 de 1
    • Grab the headphone jack from inside the case and pull it toward the speaker until you can fully remove it from the device.
3 autres ont terminé cette réparation.
MacKinley
Membre depuis le 10/22/13
811 Réputation
5 tutoriels rédigés
Équipe
University of Maryland, Team 1-1, Shastany Fall 2013 Membre de l'équipe University of Maryland, Team 1-1, Shastany Fall 2013
UMD-SHASTANY-F13S1G1
3 membres
5 tutoriels rédigés
1 commentaire de tutoriel
There Is a toroidal transformer inside ?
Jack redmond - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 13
Total : 1,953
