Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Disassembling Mercedes W123 Antenna Motor
Ce dont vous avez besoin
    1. Disassembling Mercedes W123 Antenna Motor, Antenna Motor: étape 1, image 1 de 3 Disassembling Mercedes W123 Antenna Motor, Antenna Motor: étape 1, image 2 de 3 Disassembling Mercedes W123 Antenna Motor, Antenna Motor: étape 1, image 3 de 3
      • Begin by un-clipping the motor housing cover.
      • There are a total of fourteen clips. Five on each of the long side, and two on top and bottom of the housing.
      • The plastic of the housing and lid is very durable, however the thin plastic where the clips enter is an exception. The odds are that you will crack some of these areas as you remove the lid. Do not fret, as the lid will stay closed even with just a few of the clips. The fact that there are fourteen speaks to the over-engineering at Mercedes Benz.
      Demander à FixBot
      Ajouter un commentaire
    2. Disassembling Mercedes W123 Antenna Motor: étape 2, image 1 de 3 Disassembling Mercedes W123 Antenna Motor: étape 2, image 2 de 3 Disassembling Mercedes W123 Antenna Motor: étape 2, image 3 de 3
      • As the clips come lose use a metal spudger to separate the cover from the body of the housing.
      • It will eventually lift off and can be set aside.
      Demander à FixBot
    3. Disassembling Mercedes W123 Antenna Motor: étape 3, image 1 de 1
      • Make note of the rubber seal that goes around the body of the motor in a channel, sealing the cover to the body. If this seal is old a dry rotted it will need to be replaced, or a proper liquid sealant will need to be used in its place, if the motor is being re-used.
      Demander à FixBot
    4. Disassembling Mercedes W123 Antenna Motor: étape 4, image 1 de 1
      • The basic internal components of the motor are as follows:
      • Control board
      • Electric motor
      • Plastic drive gears
      • Antenna shaft
      • To operate the antenna up and down, the electric motor turns in the appropriate direction which turns the worm gear. The worm gear tuns the upper plastic drive gear. That spins the lower plastic gear which then moves the ribbed plastic cable inside the cable housing below the gears, all of which you will see later.
      Demander à FixBot
    5. Disassembling Mercedes W123 Antenna Motor: étape 5, image 1 de 1
      • You can see the accumulation of dirt and debris on these gears. If the antenna shaft had not seized it would only have been a matter of time before the gears wore or broke.
      Demander à FixBot
    6. Disassembling Mercedes W123 Antenna Motor: étape 6, image 1 de 2 Disassembling Mercedes W123 Antenna Motor: étape 6, image 2 de 2
      • Continue disassembly by unscrewing the two Phillips screws holding the electric motor in place.
      Demander à FixBot
    7. Disassembling Mercedes W123 Antenna Motor: étape 7, image 1 de 3 Disassembling Mercedes W123 Antenna Motor: étape 7, image 2 de 3 Disassembling Mercedes W123 Antenna Motor: étape 7, image 3 de 3
      • Remove the two rubber buffers that keep the case cover separated properly from the motors and gears.
      Demander à FixBot
    8. Disassembling Mercedes W123 Antenna Motor: étape 8, image 1 de 1
      • Use a metal spudger or flat blade screwdriver to remove the c-clip holding the gears to the bushing and shaft.
      Demander à FixBot
    9. Disassembling Mercedes W123 Antenna Motor: étape 9, image 1 de 1
      • Use a metal spudger to gently begin lifting the gears from the shaft.
      Demander à FixBot
    10. Disassembling Mercedes W123 Antenna Motor: étape 10, image 1 de 1
      • As the gears begin to lift, the electric motor will likely pop loose. It can be rested off to the side; it is wired to the control board so it cannot be removed fully at this time.
      Demander à FixBot
    11. Disassembling Mercedes W123 Antenna Motor: étape 11, image 1 de 2 Disassembling Mercedes W123 Antenna Motor: étape 11, image 2 de 2
      • Continue lifting the gears out of their housing until they are free.
      • As you can see, there are actually two gears in the housing.
      Demander à FixBot
    12. Disassembling Mercedes W123 Antenna Motor: étape 12, image 1 de 2 Disassembling Mercedes W123 Antenna Motor: étape 12, image 2 de 2
      • The gears can be separated by simply pulling them apart with your hands.
      • Make note of which gear is the upper gear, and of the alignment of the gears and the spring together.
      Demander à FixBot
    13. Disassembling Mercedes W123 Antenna Motor: étape 13, image 1 de 3 Disassembling Mercedes W123 Antenna Motor: étape 13, image 2 de 3 Disassembling Mercedes W123 Antenna Motor: étape 13, image 3 de 3
      • Lift the metal gear bushing up and off of the housing and set it aside.
      Demander à FixBot
    14. Disassembling Mercedes W123 Antenna Motor: étape 14, image 1 de 1
      • Unscrew the Phillips head screw that helps hold the antenna shaft to the body.
      Demander à FixBot
    15. Disassembling Mercedes W123 Antenna Motor: étape 15, image 1 de 2 Disassembling Mercedes W123 Antenna Motor: étape 15, image 2 de 2
      • Remove the outer sleeve on the shaft from the body by rotating it counter-clockwise.
      • Once loose from the body it can be pulled up the antenna shaft and out of the way.
      Demander à FixBot
    16. Disassembling Mercedes W123 Antenna Motor: étape 16, image 1 de 1
      • Pull the ribbed plastic cable connected to the antenna shaft out of the body of the motor.
      Demander à FixBot
    17. Disassembling Mercedes W123 Antenna Motor: étape 17, image 1 de 1
      • Now you can remove the gear and cable housing. It seems to work best to rotate the housing up and in the direction of the antenna shaft opening before angling it up and pulling it out of the motor body.
      Demander à FixBot
    18. Disassembling Mercedes W123 Antenna Motor: étape 18, image 1 de 2 Disassembling Mercedes W123 Antenna Motor: étape 18, image 2 de 2
      • This leaves the lower cable retainer in place.
      • Lift it up and out.
      • Note the thin metal washer at the center of this.
      Demander à FixBot
    19. Disassembling Mercedes W123 Antenna Motor: étape 19, image 1 de 3 Disassembling Mercedes W123 Antenna Motor: étape 19, image 2 de 3 Disassembling Mercedes W123 Antenna Motor: étape 19, image 3 de 3
      • Remove the three rubber buffers.
      • Remove the gear shaft.
      Demander à FixBot
    20. Disassembling Mercedes W123 Antenna Motor: étape 20, image 1 de 2 Disassembling Mercedes W123 Antenna Motor: étape 20, image 2 de 2
      • You now have an empty motor housing, besides the control board.
      • This disassembly does not cover the electric motor as everything is in plain sight.
      • Worm gear
      • Motor
      • Small belt driven pulleys for worm gear
      Demander à FixBot
12 autres ont terminé cette réparation.
Nicolas Siemsen
Membre depuis le 12/06/13
40 559 Réputation
79 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
335 membres
8 260 tutoriels rédigés
9 commentaires de tutoriel
Great guide, I would that this antenna fix also applies to the W201 (1984 190e) model as well. Also, if the small gear is worn (like mine was) it can be fixed by removing the old gear with a Dremel tool and using a #14 gear which can be found at Hobby Shop specializing in Radio controlled cars and planes.
ajayme44 - Réponse Partager
Hu can u give the website of hobby shop since I'm having a similar problem like yours.....my small plastic gear has disintegrated into pieces. Contact on WhatsApp +27814517603
Cecil Petersen - Réponse Partager
Great disassembly guide but when I get the cover off I find the rubber drive belt is missing. Where can I get this part to replace? The Badger
Peter Brock - Réponse Partager
great disassembly guide for the mechanism but when the cover is off I find the rubber drive belt missing! Where can I get this part....assuming the motor still works and nothing else is wrong. The badger
The teeth on a small gear are broken off - everything else works fine - Where can I buy replacement gears ?
Charles Rannacher - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 19
30 derniers jours : 72
Total : 14,849
