Aller au contenu principal
Disassembling Mercedes W123 Glove Box Liner
Ce dont vous avez besoin
  1. Disassembling Mercedes W123 Glove Box Liner, Glove Box Liner: étape 1, image 1 de 1
    • Start by opening the glove box.
  2. Disassembling Mercedes W123 Glove Box Liner: étape 2, image 1 de 2 Disassembling Mercedes W123 Glove Box Liner: étape 2, image 2 de 2
    • Remove the two phillips screws in the glove box door catch, then remove it.
  3. Disassembling Mercedes W123 Glove Box Liner: étape 3, image 1 de 2 Disassembling Mercedes W123 Glove Box Liner: étape 3, image 2 de 2
    • Gently pry apart the expansion plug in the glove box clips. There will be a row of them on top, and on the bottom.
    • Once you've pried it out part of the way you can pull it the rest of the way out by hand, or gently with needle nose pliers.
  4. Disassembling Mercedes W123 Glove Box Liner: étape 4, image 1 de 1
    • You can then pry the clips out of the liner. Remove them all.
  5. Disassembling Mercedes W123 Glove Box Liner: étape 5, image 1 de 1
    • Gently pry down the cover for the glove box lamp.
  6. Disassembling Mercedes W123 Glove Box Liner: étape 6, image 1 de 1
    • Now unplug the two connections from the lamp and remove the lamp housing.
    • Be sure to make note of the orientation of the two wires for re-installation.
  7. Disassembling Mercedes W123 Glove Box Liner: étape 7, image 1 de 1
    • Now the glove box liner will pull out by hand.
6 autres ont terminé cette réparation.
Nicolas Siemsen
Membre depuis le 12/06/13
39 040 Réputation
79 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
322 membres
2 532 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 62
Total : 11,094
