Aller au contenu principal
Disassembling Mercedes W123 Kick Panel
Ce dont vous avez besoin
  1. Disassembling Mercedes W123 Kick Panel, Kick Panel: étape 1, image 1 de 1
    • Begin by gently prying out the covers for the screws on the upper edge of the kick panel.
  2. Disassembling Mercedes W123 Kick Panel: étape 2, image 1 de 1
    • Then remove these screws.
  3. Disassembling Mercedes W123 Kick Panel: étape 3, image 1 de 2 Disassembling Mercedes W123 Kick Panel: étape 3, image 2 de 2
    • Then remove any metal screws, and any plastic trim screws, at the sides of the kick panel below the dash.
  4. Disassembling Mercedes W123 Kick Panel: étape 4, image 1 de 2 Disassembling Mercedes W123 Kick Panel: étape 4, image 2 de 2
    • Now lower the panel down and rest if on the floor.
    • It can be removed full for further ease of access, depending on the job at hand.
  5. Disassembling Mercedes W123 Kick Panel: étape 5, image 1 de 3 Disassembling Mercedes W123 Kick Panel: étape 5, image 2 de 3 Disassembling Mercedes W123 Kick Panel: étape 5, image 3 de 3
    • Now you'll want to identify some of the components you are looking at so you can begin working on the one that is having issues.
    • Here are some of the ones you may find. This car is a 1985 300D; if you have an older model the items are likely a bit different.
    • Heater blower motor
    • Over-voltage protection relay
    • Air-conditioning expansion valve
11 autres ont terminé cette réparation.
Nicolas Siemsen
Membre depuis le 12/06/13
39 284 Réputation
79 tutoriels rédigés
Équipe
Master Techs Membre de l'équipe Master Techs
Community
321 membres
1 525 tutoriels rédigés
Un commentaire
Dear Nicolas.I have one 123 300D. 1983. This days i have the follow problem.When i turn on the switch the engine heater light just lights with low brightness and the same time the diesel level goes to full.as i turn on the engine the temperature starts going up also and in few minutes time goes until full.if it is night and i turn on the head lights on high beam the engine heat light lights with the high beam light also.After 15-20 minutes time when i driving the car everything return on normal.I check the engine heaters and are ok.my battery is new.Please help me were to check and loose this problem.
Best Regards
Pavlos
melaspavlos - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 19
30 derniers jours : 77
Total : 13,661
