Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
This guide will show you how to replace a motor tread.
  1. Loosen the screws on the serial port by turning them counter clockwise by hand. After loosening the screws, pull the serial port out. After loosening the screws, pull the serial port out.
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
  2. Lift lid to its vertical position. Pull lid straight up to remove it from the scanner. Pull lid straight up to remove it from the scanner.
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
  3. Push the plastic opening tools into the crack between the top and the bottom of the chassis. Push the plastic opening tools into the crack between the top and the bottom of the chassis. Push the plastic opening tools into the crack between the top and the bottom of the chassis.
    • Push the plastic opening tools into the crack between the top and the bottom of the chassis.
  4. After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis. Go all the way along the chassis until you can lift the upper lid. Go all the way along the chassis until you can lift the upper lid.
    • After placing one plastic opening tool into the slit, slide other plastic opening tools along the slit to detach the top from the bottom of the chassis.
    • Go all the way along the chassis until you can lift the upper lid.
  5. Fix Kits pour écrans LCD d'iPhone
    L'option économique couverte par notre garantie à vie.
    Acheter des kits
    Réduisez les coûts de réparation et non pas la qualité.
    Acheter des kits
  6. Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid. Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid. Grab the ribbon cable and gently pull it out of its slot with your fingers.
    • Do not fully remove the lid until you remove the ribbon cable attached to the front of the upper lid.
    • Do this by grabbing the upper lid from the sides and rotating it ninety degrees so it is perpendicular to the bottom lid.
    • Grab the ribbon cable and gently pull it out of its slot with your fingers.
    • The upper lid can now safely be removed from the bottom lid.
  7. Locate the stepper motor. With the front of the scanner facing you, the motor is located at the top left. Disconnect the white connector from the vertical standing circuit board.
    • Locate the stepper motor. With the front of the scanner facing you, the motor is located at the top left.
    • Disconnect the white connector from the vertical standing circuit board.
  8. Using a #2 Philips Screwdriver, unscrew the two 7.7mm screws holding the stepper motor in place. The stepper motor will become loose, but not completely free. The stepper motor will become loose, but not completely free.
    • Using a #2 Philips Screwdriver, unscrew the two 7.7mm screws holding the stepper motor in place.
    • The stepper motor will become loose, but not completely free.
  9. Using tweezers gently remove the tread from the black gear on the stepper motor. The stepper motor will become completely free. The stepper motor will become completely free.
    • Using tweezers gently remove the tread from the black gear on the stepper motor.
    • The stepper motor will become completely free.
  10. Facing the front of the scanner you will see a white plastic wheel holding the other end of the tread. Pull the spring towards you until it snaps off the side wall releasing the tension in the spring.
    • Facing the front of the scanner you will see a white plastic wheel holding the other end of the tread.
    • Pull the spring towards you until it snaps off the side wall releasing the tension in the spring.
    • Using a #2 Philips Screwdriver, unscrew the single 5.88mm screw holding the mount of the plastic wheel in place.
  11. The plastic wheel and it's mount will be loose.
    • The plastic wheel and it's mount will be loose.
    • Remove the shaft holding the plastic wheel and the mount together
    • The tread will be completely loose.
Steven Shaginyan
Membre depuis le 12/10/2011
39 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 6-9, Regan Fall 2011 Membre de l'équipe Cal Poly, Team 6-9, Regan Fall 2011
CPSU-REGAN-F11S6G9
2 membres
11 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 1,237
