Aller au contenu principal
Disassembling Midland X-tra Talk Radio LXT118 Speaker
Ce dont vous avez besoin
  1. Disassembling Midland X-tra Talk Radio LXT118 Speaker, Batteries: étape 1, image 1 de 2 Disassembling Midland X-tra Talk Radio LXT118 Speaker, Batteries: étape 1, image 2 de 2
    • First, apply pressure with your thumb on the top of the battery cover.
    • Next, pull down on the cover until it begins to slide.
  2. Disassembling Midland X-tra Talk Radio LXT118 Speaker: étape 2, image 1 de 1
    • Finally, once the cover is completely off, pry up the old batteries with your finger or a strong, skinny tool (i.e. spudger).
  3. Disassembling Midland X-tra Talk Radio LXT118 Speaker, Case: étape 3, image 1 de 1
    • Unscrew the six 8.0 millimeter long, #0 screws on the backside of the case using the Phillips #0 screwdriver.
  4. Disassembling Midland X-tra Talk Radio LXT118 Speaker: étape 4, image 1 de 1
    • Detach back part of the case by gently lifting up.
  5. Disassembling Midland X-tra Talk Radio LXT118 Speaker, Speaker: étape 5, image 1 de 1
    • Remove the circuit board from the front part of the radio case.
    • Clip the red and black connecting wires at the base closest to the circuit bored in the spots denoted by the two red circles.
  6. Disassembling Midland X-tra Talk Radio LXT118 Speaker: étape 6, image 1 de 1
    • Scrape off the glue on the outer lining of the speaker using the metal spudger.
  7. Disassembling Midland X-tra Talk Radio LXT118 Speaker: étape 7, image 1 de 1
    • Pry the speaker from the case using the metal spudger.
    • This should not take excessive force, so make sure all remaining glue is scraped off from the edges if it will not easily come out.
  8. Disassembling Midland X-tra Talk Radio LXT118 Speaker: étape 8, image 1 de 1
    • The speaker is now disassembled!
3 autres ont terminé cette réparation.
James Tucker Dunn
Membre depuis le 01/18/13
371 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 19-43, Regan Winter 2013 Membre de l'équipe Cal Poly, Team 19-43, Regan Winter 2013
CPSU-REGAN-W13S19G43
3 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 2
Total : 578
