Aller au contenu principal
Disassembling Motorola Defy XT
Ce dont vous avez besoin
  1. Disassembling Motorola Defy XT, Disassembling Motorola Defy XT: étape 1, image 1 de 1
    • Switch off the mobile.
  2. Disassembling Motorola Defy XT: étape 2, image 1 de 1
    • Unlock the back case before open.
  3. Disassembling Motorola Defy XT: étape 3, image 1 de 1
    • Remove the battery
    • Remove the memory card
    • Remove the Sim card
  4. Disassembling Motorola Defy XT: étape 4, image 1 de 2 Disassembling Motorola Defy XT: étape 4, image 2 de 2
    • Remove 6 screws
    • Tear off a part of label
    • Release the usb cover
  5. Disassembling Motorola Defy XT: étape 5, image 1 de 1
    • Open the green case part by yours fingernail from left side to the right side with the usb socket
    • Be care of your labels
    • If you want to repair the SIM card slot legs, be sure no short circuits in 6 legs.
  6. Disassembling Motorola Defy XT: étape 6, image 1 de 2 Disassembling Motorola Defy XT: étape 6, image 2 de 2
    • To release the PCB for cleaning the Display the the touch screen, remove 2 PARTS by fingernail.
    • 1. Touchscreen adapter
    • 2. Sticker between the touchscreen PCB & mobile PCB
    • Remove the mobile PCB much careful form top right. Be care the touchscreen circuits.
  7. Disassembling Motorola Defy XT: étape 7, image 1 de 3 Disassembling Motorola Defy XT: étape 7, image 2 de 3 Disassembling Motorola Defy XT: étape 7, image 3 de 3
    • You can use a cloth, USB vacuum cleaner (be careful of the components in the green case), and adhesive tape to remove all the dust.
    • That finger pin is left by the Motorola Support Center in Hong Kong!!
    • You can also clean the camera lens on PCB
  8. Disassembling Motorola Defy XT: étape 8, image 1 de 1
    • Remember to put all parts back and insert the touchscreen plugs slightly.
    • Put the green case back, make sure all locks is conneted
  9. Disassembling Motorola Defy XT: étape 9, image 1 de 1
    • You can test the mobile before screw.
    • After insert the memory card, SIM card and battery, switch on the phone
    • Test call in and call out, also check the speaker
    • Open the map Apps to test Wifi and GPS
    • Bluetooth file transfer
    • Camera test and save in sd card
    • Check the sd card files
    • Try to connect with PC
  10. Disassembling Motorola Defy XT: étape 10, image 1 de 3 Disassembling Motorola Defy XT: étape 10, image 2 de 3 Disassembling Motorola Defy XT: étape 10, image 3 de 3
    • If all works, remove the SIM card and battery.
    • Recheck the label is it on the top of the green case
    • Screws up all 6 screws
    • Put back all battery and SIM card
    • Close the back case and lock it
    • Close the USB cover
    • Done
  11. Disassembling Motorola Defy XT: étape 11, image 1 de 3 Disassembling Motorola Defy XT: étape 11, image 2 de 3 Disassembling Motorola Defy XT: étape 11, image 3 de 3
    • If you want to explore what inside of the battery with PCB. Here is the step to follow.
    • Remove the label
    • Remove the black rubber
    • Tear the battery by hand (Be patient to repeat it many time) ***do not use any metal tools to cut it out!!
    • Also you can tear PCB by hand
  12. Disassembling Motorola Defy XT: étape 12, image 1 de 1
    • Remove the black rubber Tear the battery by hand (Be patient to repeat it many time)
  13. Disassembling Motorola Defy XT: étape 13, image 1 de 1
    • ***do not use any metal tools to cut it out!!
  14. Disassembling Motorola Defy XT: étape 14, image 1 de 1
2 autres ont terminé cette réparation.
Wing Nga PANG
Membre depuis le 08/25/14
151 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 15
Total : 959
