Aller au contenu principal
Motorola V180 Connector Ribbon Replacement
Ce dont vous avez besoin
  1. Motorola V180 Connector Ribbon Replacement, Connector Ribbon: étape 1, image 1 de 1
    • Gently tug on the upper edge of the faceplate, and it will easily detach.
  2. Motorola V180 Connector Ribbon Replacement: étape 2, image 1 de 1
    • Remove the four screws securing the front cover.
  3. Motorola V180 Connector Ribbon Replacement: étape 3, image 1 de 1
    • Gently glide the metallic silver cover outward.
    • This piece is wedged in tight. Try to slide out one hook at a time, instead of both simultaneously.
  4. Motorola V180 Connector Ribbon Replacement: étape 4, image 1 de 1
    • Insert a pair of tweezers between the silver and black sections of the cover.
    • The silver section should now easily snap away.
  5. Motorola V180 Connector Ribbon Replacement: étape 5, image 1 de 1
    • The black rubber component can now easily be taken off.
  6. Motorola V180 Connector Ribbon Replacement: étape 6, image 1 de 1
    • Use a soldering iron to detach the connector ribbon from the phone.
Tyler Knisley
Membre depuis le 05/07/10
1 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 6-16, Maness Spring 2010 Membre de l'équipe Cal Poly, Team 6-16, Maness Spring 2010
CPSU-MANESS-S10S6G16
4 membres
13 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 7
Total : 2,619
