Aller au contenu principal
Disassembling Motorola i850 Keypad
Ce dont vous avez besoin
  1. Disassembling Motorola i850 Keypad, Disassembling Motorola i850 Back Cover: étape 1, image 1 de 1
    • Use your thumb to slide the back cover locker away from the antenna.
  2. Disassembling Motorola i850 Keypad: étape 2, image 1 de 2 Disassembling Motorola i850 Keypad: étape 2, image 2 de 2
    • Slide the back cover towards the antenna while lifting the cover away from the phone.
  3. Disassembling Motorola i850 Keypad, Battery: étape 3, image 1 de 1
    • Place your thumb on the indicated corner while stabilizing the phone and the upper portion of the battery with your forefinger.
  4. Disassembling Motorola i850 Keypad: étape 4, image 1 de 2 Disassembling Motorola i850 Keypad: étape 4, image 2 de 2
    • Lift the battery out of the phone while pushing it towards the antenna.
  5. Disassembling Motorola i850 Keypad, Keypad: étape 5, image 1 de 1
    • Once battery is removed, untighten the screws located near the edges of the device with a Phillips #00 Screwdriver.
  6. Disassembling Motorola i850 Keypad: étape 6, image 1 de 3 Disassembling Motorola i850 Keypad: étape 6, image 2 de 3 Disassembling Motorola i850 Keypad: étape 6, image 3 de 3
    • Grip the device firmly with both hands and carefully open the device.
    • Warning: Interior hardware inside the device can be easily damaged.
  7. Disassembling Motorola i850 Keypad: étape 7, image 1 de 2 Disassembling Motorola i850 Keypad: étape 7, image 2 de 2
    • Carefully remove the hardware by gripping the side of the hardware attachment with a tweezer.
  8. Disassembling Motorola i850 Keypad: étape 8, image 1 de 2 Disassembling Motorola i850 Keypad: étape 8, image 2 de 2
    • Carefully grip the side of the hardware attachment with a tweezer and detach from device.
  9. Disassembling Motorola i850 Keypad: étape 9, image 1 de 3 Disassembling Motorola i850 Keypad: étape 9, image 2 de 3 Disassembling Motorola i850 Keypad: étape 9, image 3 de 3
    • Place the back of the device on your hand and flip it over with the other hand.
    • Carefully lift the device to remove interior hardware.
    • The structure of the keypad should easily be loose from flipping the device.
  10. Disassembling Motorola i850 Keypad: étape 10, image 1 de 3 Disassembling Motorola i850 Keypad: étape 10, image 2 de 3 Disassembling Motorola i850 Keypad: étape 10, image 3 de 3
    • Carefully remove the keypad by griping on the side of the plastic with a tweezer.
    • WARNING: The plastic keypad is sensitive and can be easily damaged.
Tony Chen
Membre depuis le 04/08/10
1 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 34-56, Forte Spring 2010 Membre de l'équipe Cal Poly, Team 34-56, Forte Spring 2010
CPSU-FORTE-S10S34G56
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 1,640
