Introduction
The removal and replacement of the LCD board.
  1. Open the flip cover of the phone with the LCD screen facing towards you.
    • Open the flip cover of the phone with the LCD screen facing towards you.
  2. Use a Razor Blade to remove the screw covers.
    • Use a Razor Blade to remove the screw covers.
    • Razor Blade is very sharp. Use caution.
    • Unscrew the screws using a Phillips #00 Screwdriver.
    • Insert a Spudger into the side crack of the flip cover and slowly separate the phone cover from the case.
    • Gently separate the flip cover case from the phone with your hands when the crack is wide enough.
    • Partially close the flip cover of the phone in order to take off the outer case.
    • Completely remove the outer casing from the phone.
    • Place your thumb underneath the protective metal covering to remove it from the phone.
    • Gently detach the black microchip from the phone with a Tweezer.
    • Prop out the LCD board from the phone using your fingertips.
    • Remove the LCD board from the phone by grabbing the bottom side of the LCD board.
Andrew Aw
Membre depuis le 08/04/2010
1 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 34-56, Forte Spring 2010 Membre de l'équipe Cal Poly, Team 34-56, Forte Spring 2010
CPSU-FORTE-S10S34G56
4 membres
10 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 2,282
