Aller au contenu principal
Disassembling Motorola i90c Internal Backplate
Ce dont vous avez besoin
  1. Disassembling Motorola i90c Internal Backplate, Battery: étape 1, image 1 de 3 Disassembling Motorola i90c Internal Backplate, Battery: étape 1, image 2 de 3 Disassembling Motorola i90c Internal Backplate, Battery: étape 1, image 3 de 3
    • Slide the notch downward while pulling the back cover off to remove it.
  2. Disassembling Motorola i90c Internal Backplate: étape 2, image 1 de 3 Disassembling Motorola i90c Internal Backplate: étape 2, image 2 de 3 Disassembling Motorola i90c Internal Backplate: étape 2, image 3 de 3
    • Use your fingers to push the battery upward from the bottom.
    • Lift upwards to remove the battery.
  3. Disassembling Motorola i90c Internal Backplate, Antenna: étape 3, image 1 de 2 Disassembling Motorola i90c Internal Backplate, Antenna: étape 3, image 2 de 2
    • Unscrew the antenna in a counter-clockwise fashion.
    • Remove the aluminum cover.
  4. Disassembling Motorola i90c Internal Backplate, Disassembling Motorola i90c Internal Backplate: étape 4, image 1 de 3 Disassembling Motorola i90c Internal Backplate, Disassembling Motorola i90c Internal Backplate: étape 4, image 2 de 3 Disassembling Motorola i90c Internal Backplate, Disassembling Motorola i90c Internal Backplate: étape 4, image 3 de 3
    • Unscrew the 3 screws shown.
    • Lift up the right part of the Nextel logo and unscrew the screw underneath.
  5. Disassembling Motorola i90c Internal Backplate: étape 5, image 1 de 2 Disassembling Motorola i90c Internal Backplate: étape 5, image 2 de 2
    • DO NOT force the cover off as it could damage the ribbon cable!
    • Gently lift the back cover off.
  6. Disassembling Motorola i90c Internal Backplate: étape 6, image 1 de 3 Disassembling Motorola i90c Internal Backplate: étape 6, image 2 de 3 Disassembling Motorola i90c Internal Backplate: étape 6, image 3 de 3
    • Carefully pry off the connection between the headphone jack and logic board.
Grant Glazebrook
Membre depuis le 04/14/10
7 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 29-61, Johann Spring 2010 Membre de l'équipe Cal Poly, Team 29-61, Johann Spring 2010
CPSU-JOHANN-S10S29G61
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 1,328
