Introduction
Removing the stand from the rest of the monitor allows you to access and replace parts inside the display assembly.
Before beginning this guide, prepare a clean, flat surface to use as a workstation. Avoid working over carpeting, as small screws are used and, if dropped, may be lost in the carpet.
Pièces
Aucune pièce nécessaire.
Place the monitor face down on a clean, flat surface.
  • Place the monitor face down on a clean, flat surface.
Ajouter un commentaire
Firmly remove the back panel of the stand by pulling it up and away from the monitor.
  • Firmly remove the back panel of the stand by pulling it up and away from the monitor.
  • Unscrew the two 6mm Phillips PH2 screws to detach the stand enclosure from the stand.
  • Firmly grasp the stand enclosure with your hand and slide it to base of stand.
  • Unscrew the two 14.5mm Phillips PH2 screws holding the stand to the monitor.
  • Lift the the stand straight up to remove it.
Michela Upson
Membre depuis le 17/10/2013
107 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 11-36, Amido Fall 2013 Membre de l'équipe Cal Poly, Team 11-36, Amido Fall 2013
CPSU-AMIDO-F13S11G36
5 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 331
