Aller au contenu principal
Disassembling Nikon Coolpix 5600 Flash Unit
Ce dont vous avez besoin
  1. Disassembling Nikon Coolpix 5600 Flash Unit, Remove Screws: étape 1, image 1 de 3 Disassembling Nikon Coolpix 5600 Flash Unit, Remove Screws: étape 1, image 2 de 3 Disassembling Nikon Coolpix 5600 Flash Unit, Remove Screws: étape 1, image 3 de 3
    • Remove the screws from the bottom, right, and left side of camera.
  2. Disassembling Nikon Coolpix 5600 Flash Unit, Remove back: étape 2, image 1 de 1
    • Remove the back of the camera, this may require force.
  3. Disassembling Nikon Coolpix 5600 Flash Unit, Remove Metal Bracket: étape 3, image 1 de 1
    • Unscrew the right metal bracket of the viewing lens
  4. Disassembling Nikon Coolpix 5600 Flash Unit, Remove front of camera: étape 4, image 1 de 1
    • Unscrew the top right corner screw
  5. Disassembling Nikon Coolpix 5600 Flash Unit: étape 5, image 1 de 1
    • Unscrew the bottom right corner screw.
  6. Disassembling Nikon Coolpix 5600 Flash Unit: étape 6, image 1 de 2 Disassembling Nikon Coolpix 5600 Flash Unit: étape 6, image 2 de 2
    • Pull the grey circular facet that sits on the bottom outside of the camera off - may have to use force.
  7. Disassembling Nikon Coolpix 5600 Flash Unit: étape 7, image 1 de 2 Disassembling Nikon Coolpix 5600 Flash Unit: étape 7, image 2 de 2
    • Pull the front of the camera off of the mother board.
  8. Disassembling Nikon Coolpix 5600 Flash Unit, Disassembling Nikon Coolpix 5600 Flash Unit: étape 8, image 1 de 1
    • Unscrew the grey plastic around the screen
  9. Disassembling Nikon Coolpix 5600 Flash Unit: étape 9, image 1 de 1
    • Twist the grey bracket counterclockwise to remove it from the silver LCD bracket.
  10. Disassembling Nikon Coolpix 5600 Flash Unit: étape 10, image 1 de 1
    • Maneuver to detach the flash bulb.
  11. Disassembling Nikon Coolpix 5600 Flash Unit: étape 11, image 1 de 1
    • Unscrew the metal bracket under the lens
  12. Disassembling Nikon Coolpix 5600 Flash Unit: étape 12, image 1 de 1
    • Slide the plastic bracket through the metal bracket.
    • Remove the orange cable from the motherboard.
  13. Disassembling Nikon Coolpix 5600 Flash Unit: étape 14, image 1 de 1
    • Pull the black tape off.
  14. Disassembling Nikon Coolpix 5600 Flash Unit: étape 15, image 1 de 1
    • Unscrew the two screws underneath.
    • Remove lens
Crista Riedy
Membre depuis le 02/12/13
406 Réputation
3 tutoriels rédigés
Équipe
Ohio State, Team 1-2, Buehl Spring 2013 Membre de l'équipe Ohio State, Team 1-2, Buehl Spring 2013
OSU-BUEHL-S13S1G2
2 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 17
Total : 742
