Aller au contenu principal
Disassembling Nokia 2366i Main Display
Ce dont vous avez besoin
  1. Disassembling Nokia 2366i Main Display, Battery: étape 1, image 1 de 2 Disassembling Nokia 2366i Main Display, Battery: étape 1, image 2 de 2
    • Turn off the phone.
    • Position the phone so that the back side is in view.
  2. Disassembling Nokia 2366i Main Display: étape 2, image 1 de 1
    • Apply pressure on the cover while simultaneously sliding the cover downward.
    • Remove the back battery cover.
  3. Disassembling Nokia 2366i Main Display: étape 3, image 1 de 3 Disassembling Nokia 2366i Main Display: étape 3, image 2 de 3 Disassembling Nokia 2366i Main Display: étape 3, image 3 de 3
    • Insert the spudger between the base of the phone and the phone battery.
    • Position the phone so that the battery won't fall out of the phone.
    • Carefully lift the battery out of the phone.
    • The battery lifts out of the phone easily.
  4. Disassembling Nokia 2366i Main Display, Front Cover: étape 4, image 1 de 1
    • Keep the phone closed.
    • Hold the phones sideways with the front cover of the phone facing up.
  5. Disassembling Nokia 2366i Main Display: étape 5, image 1 de 2 Disassembling Nokia 2366i Main Display: étape 5, image 2 de 2
    • Find the slight crease on the side that divides the display assembly in half.
    • Slowly wedge the spudger into the crease.
    • It's a little difficult to perform this step because the crease is narrow. Do not rush because you may damage the phone
  6. Disassembling Nokia 2366i Main Display: étape 6, image 1 de 2 Disassembling Nokia 2366i Main Display: étape 6, image 2 de 2
    • Run the spudger all along the crease while lifting up.
    • Separate the front cover from the front base.
  7. Disassembling Nokia 2366i Main Display, Main Display: étape 7, image 1 de 2 Disassembling Nokia 2366i Main Display, Main Display: étape 7, image 2 de 2
    • Remove the four 5mm screws on the metal casing using the T6 Torx screwdriver.
  8. Disassembling Nokia 2366i Main Display: étape 8, image 1 de 2 Disassembling Nokia 2366i Main Display: étape 8, image 2 de 2
    • Using the spudger, disconnect the green display cable.
  9. Disassembling Nokia 2366i Main Display: étape 9, image 1 de 3 Disassembling Nokia 2366i Main Display: étape 9, image 2 de 3 Disassembling Nokia 2366i Main Display: étape 9, image 3 de 3
    • Lift the metal casing.
    • Be careful not to pull the casing too hard because it is still attached to the phone by a wire.
    • Remove the main display from under the metal casing.
Michael Machado
Membre depuis le 01/21/11
334 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 1-14, Amido Winter 2011 Membre de l'équipe Cal Poly, Team 1-14, Amido Winter 2011
CPSU-AMIDO-W11S1G14
5 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 1,059
