Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Disassembling Nokia 3395 Inner Components
Ce dont vous avez besoin
  1. Disassembling Nokia 3395 Inner Components, Back Case: étape 1, image 1 de 3 Disassembling Nokia 3395 Inner Components, Back Case: étape 1, image 2 de 3 Disassembling Nokia 3395 Inner Components, Back Case: étape 1, image 3 de 3
    • Turn the phone off.
    • Hold the phone, and gently press the white button located at the bottom of the phone.
    • While pressing the button, slide the back plate upwards, opening the plate.
    Demander à FixBot
  2. Disassembling Nokia 3395 Inner Components, Battery: étape 2, image 1 de 2 Disassembling Nokia 3395 Inner Components, Battery: étape 2, image 2 de 2
    • Locate grey buttons beneath battery (shown).
    • Spread buttons simultaneously away from each other and the battery will pop out.
    • Remove battery from phone.
    Demander à FixBot
  3. Disassembling Nokia 3395 Inner Components, Front Case: étape 3, image 1 de 2 Disassembling Nokia 3395 Inner Components, Front Case: étape 3, image 2 de 2
    • Push the two black buttons on the side with your thumbs forward. This will release the front faceplate.
    • Flip over the device, and pry the faceplate away.
    Demander à FixBot
  4. Disassembling Nokia 3395 Inner Components, Screen: étape 4, image 1 de 2 Disassembling Nokia 3395 Inner Components, Screen: étape 4, image 2 de 2
    • Remove six T6 screws.
    Demander à FixBot
  5. Disassembling Nokia 3395 Inner Components: étape 5, image 1 de 2 Disassembling Nokia 3395 Inner Components: étape 5, image 2 de 2
    • Insert spudger between screen assembly and phone body.
    • Spread apart as shown. Avoid damaging the screen assembly by removing the screen slowly.
    Demander à FixBot
  6. Disassembling Nokia 3395 Inner Components, Logic Board: étape 6, image 1 de 2 Disassembling Nokia 3395 Inner Components, Logic Board: étape 6, image 2 de 2
    • Remove logic board as shown.
    Demander à FixBot
  7. Disassembling Nokia 3395 Inner Components, Inner Components: étape 7, image 1 de 1
    • Use the following legend to locate each component:
    • Microphone/power assembly.
    • Vibrating unit.
    • SIM card reader.
    • Audio speaker.
    • Power toggle button.
    • Battery connector.
    Demander à FixBot
  8. Disassembling Nokia 3395 Inner Components: étape 8, image 1 de 2 Disassembling Nokia 3395 Inner Components: étape 8, image 2 de 2
    • Insert spudger between power assembly/micro-phone and phone body.
    • Pry as shown and remove the power assembly/microphone.
    Demander à FixBot
  9. Disassembling Nokia 3395 Inner Components: étape 9, image 1 de 1
    • Once located, the following components are easily removed by pulling them out with your hand.
    • Vibrating unit.
    • SIM card reader.
    • Audio speaker.
    Demander à FixBot
  10. Disassembling Nokia 3395 Inner Components: étape 10, image 1 de 2 Disassembling Nokia 3395 Inner Components: étape 10, image 2 de 2
    • Audio speaker.
    Demander à FixBot
  11. Disassembling Nokia 3395 Inner Components: étape 11, image 1 de 2 Disassembling Nokia 3395 Inner Components: étape 11, image 2 de 2
    • SIM card reader.
    Demander à FixBot
  12. Disassembling Nokia 3395 Inner Components: étape 12, image 1 de 2 Disassembling Nokia 3395 Inner Components: étape 12, image 2 de 2
    • Vibrating unit.
    Demander à FixBot
  13. Disassembling Nokia 3395 Inner Components: étape 13, image 1 de 2 Disassembling Nokia 3395 Inner Components: étape 13, image 2 de 2
    Demander à FixBot
  14. Disassembling Nokia 3395 Inner Components: étape 14, image 1 de 2 Disassembling Nokia 3395 Inner Components: étape 14, image 2 de 2
    Demander à FixBot
Nico Lee
Membre depuis le 04/19/10
83 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 30-41, Garner Spring 2010 Membre de l'équipe Cal Poly, Team 30-41, Garner Spring 2010
CPSU-GARNER-S10S30G41
4 membres
11 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 80
Total : 3,290
