Introduction
This guide helps you remove the display from the phone.
Ce dont vous avez besoin
Using your thumb, apply pressure to the battery casing (below the camera). Firmly pull towards the bottom of the phone.
Lift the battery case off of the phone.
Insert a spudger into the indention on the bottom right side of the device.
Slide the spudger upward to a second indention at the top of the phone.
The front casing will detach from the phone.
Use the flathead screwdriver to remove four screws on the upper half of the phone.
Lift the LCD up and off.
2 autres ont terminé cette réparation.
