Aller au contenu principal
Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly
Ce dont vous avez besoin
  1. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly, Battery: étape 1, image 1 de 1
    • Before taking apart your Nokia 6590i, you will need to purchase a new battery. You can find them at Amazon, Walmart, or any cell phone repair store.
    • For reference, pictured here is a photo of a new battery for the Nokia 6590i.
    • Most new batteries will have a price range of $10 to $30.
  2. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: étape 2, image 1 de 2 Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: étape 2, image 2 de 2
    • After purchasing a new battery, we can begin the replacement.
    • First, press the button on the bottom of the rear cover.
    • Second, keep the button pressed while pulling the cover downward to remove the back cover.
    • Third, lift the cover off.
  3. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: étape 3, image 1 de 1
    • Then, to remove the old battery, push it down from the top and pull it out.
    • To install the new battery, just follow this guide in reverse order!
  4. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly, Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: étape 4, image 1 de 1
    • Grip the front cover from the bottom.
  5. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: étape 5, image 1 de 1
    • Lift the front cover off.
  6. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: étape 6, image 1 de 1
    • Remove the six screws using a T6 torx screwdriver.
  7. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: étape 7, image 1 de 1
    • Insert spudger along edge of assembly and gently lift assembly away from case
  8. Disassembling Nokia 6590i Keypad, Speaker, and Screen Assembly: étape 8, image 1 de 1
    • Remove assembly from phone
Colby Leslie
Membre depuis le 10/05/10
13 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 22-3, Maness Fall 2010 Membre de l'équipe Cal Poly, Team 22-3, Maness Fall 2010
CPSU-MANESS-F10S22G3
4 membres
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,103
