Aller au contenu principal
Disassembling Nokia E61i Speaker
Ce dont vous avez besoin
  1. Disassembling Nokia E61i Speaker, Battery: étape 1, image 1 de 2 Disassembling Nokia E61i Speaker, Battery: étape 1, image 2 de 2
    • Remove the back cover to access the battery. Press the tab on the bottom of the cover.
    • Slide the back cover downwards off of the phone while pressing the tab down.
  2. Disassembling Nokia E61i Speaker: étape 2, image 1 de 1
    • Locate the bottom-left corner of the phone where there is a spot to remove the battery.
  3. Disassembling Nokia E61i Speaker: étape 3, image 1 de 1
    • Lift the battery out using your finger.
    • The E61i uses a Nokia BP-4L standard battery.
  4. Disassembling Nokia E61i Speaker, Front Cover: étape 4, image 1 de 2 Disassembling Nokia E61i Speaker, Front Cover: étape 4, image 2 de 2
    • Remove the four screws that secure the front cover to the rest of the phone using a T7 screwdriver.
  5. Disassembling Nokia E61i Speaker: étape 5, image 1 de 1
    • Remove the cover by pulling it up and off.
  6. Disassembling Nokia E61i Speaker, Display: étape 6, image 1 de 2 Disassembling Nokia E61i Speaker, Display: étape 6, image 2 de 2
    • Take off the casing and keyboard.
    • Remove the screws while holding the screen in place using a Torx T6 screwdriver.
    • Remove the single screw while holding the screen in place using a Torx T5 screwdriver.
    • Lift the ribbon off of the contact with the motherboard.
    • Firmly press the contacts into place to connect the ribbon and the motherboard when reassembling.
  7. Disassembling Nokia E61i Speaker: étape 7, image 1 de 2 Disassembling Nokia E61i Speaker: étape 7, image 2 de 2
    • Gently pull the screen off of the phone.
    • Be sure not to rip the sticker that connects the display and the motherboard.
    • Pull the silver case off to completely free the cracked or damaged screen.
  8. Disassembling Nokia E61i Speaker, Speaker: étape 8, image 1 de 2 Disassembling Nokia E61i Speaker, Speaker: étape 8, image 2 de 2
    • Remove the speaker by pulling it off of the display frame.
    • The speaker is connected to the display frame by a ring of adhesive foam (visible in second picture). By removing the speaker, this foam is torn. However, the speaker sticks quite well to the frame without reapplication of any adhesive.
Christopher Patton
Membre depuis le 04/07/11
208 Réputation
12 tutoriels rédigés
Équipe
Cal Poly, Team 9-63, Walters Spring 2011 Membre de l'équipe Cal Poly, Team 9-63, Walters Spring 2011
CPSU-WALTERS-S11S9G63
5 membres
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 2
Total : 1,833
