Pièces
Aucune pièce nécessaire.
  1. Unscrew the bottom and right side panel screws using a #00 screwdriver. (5 screws)
    • Unscrew the bottom and right side panel screws using a #00 screwdriver. (5 screws)
  2. Remove the right side panel by pulling off the large silver piece.
    • Remove the right side panel by pulling off the large silver piece.
    • Unscrew the remaining side and front panel screws using a #00 screwdriver. (3 screws)
    • Using your thumb and forefinger, pull off the silver name plate and silver "T-shape" piece. (2 pieces)
    • Remove the black front panel by sliding it towards the lens and then pulling it up off the camera.
    • Remove 3 screws from the front of the camera using a #00 screwdriver.
    • Lift the two tabs to separate the case using a spudger. (one tab on top and one tab on the right side)
    • Using a plastic spudger, lift up the black clips.
    • Still using the plastic spudger, detach the gold connector strip and white connector strip.
    • Using both hands, pull the camera apart into two pieces.
    • Still using the spudger, detach the 3 gold wire tape connectors from the inside of the camera.
    • Remove 3 screws from the inside of the camera using a #00 screwdriver.
    • Using your thumb and forefinger, pull the lens piece straight out from the body of the camera.
    • Unscrew two screws on the right side of the camera using a #00 screwdriver.
    • Still using the spudger, detach the gold wire tape connectors from the logic board.
    • Unsolder the upper right and lower left wires to remove logic board.
    • In order to remove the logic board, grab each side of it and pull up using your thumb and forefinger.
Max McIntyre
Membre depuis le 21/01/2011
511 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 13-4, Forte Winter 2011 Membre de l'équipe Cal Poly, Team 13-4, Forte Winter 2011
CPSU-FORTE-W11S13G4
6 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 9
Total : 2,967
