Introduction
Follow these instructions to learn how to remove the Olympus Stylus Tough-8010 camera's casing.
Ce dont vous avez besoin
Remove the front three screws (3.2mm) using a type T-6 head screwdriver.
Take off smaller front cover.
Carefully remove larger front cover.
Outil utilisé dans cette étape :Tweezers$4.99
Remove four screws (9.4mm) on the front of the camera using a Phillips #000
Use the plastic opening tool to release the holding clip.
Using tweezers separate the plastic strips from their connectors located on the main circuit board by lifting the small, black flaps on the connectors and pulling on the ribbons.
3 autres ont terminé cette réparation.
