Aller au contenu principal
Disassembling Optoma HD20 Cover
Ce dont vous avez besoin
  1. Disassembling Optoma HD20 Cover, Disassembling Optoma HD20 Cover: étape 1, image 1 de 2 Disassembling Optoma HD20 Cover, Disassembling Optoma HD20 Cover: étape 1, image 2 de 2
    • Twist the focal cap clockwise until it is fully extended.
    • Remove the focal cap by pulling it straight out.
  2. Disassembling Optoma HD20 Cover: étape 2, image 1 de 1
    • Use a Phillips #1 screwdriver to remove the three 7.5mm screws on the bottom of the device.
  3. Disassembling Optoma HD20 Cover: étape 3, image 1 de 1
    • Use a plastic opening tool to gently pry the top cover off of the device.
    • It is easier to pry off the cover from the back side just above the HDMI ports.
  4. Disassembling Optoma HD20 Cover: étape 4, image 1 de 1
    • When removing the cover, be cautious of the ribbon connecting the top buttons to the main circuit board. The ribbon must be disconnected before proceeding.
    • Remove the ribbon by disconnecting it from the main circuit board.
    • Lift up the clip holding it down and pull the ribbon out.
8 autres ont terminé cette réparation.
Trever
Membre depuis le 01/22/15
1 264 Réputation
6 tutoriels rédigés
Équipe
Cal Poly, Team 21-23, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 21-23, Maness Winter 2015
CPSU-MANESS-W15S21G23
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 29
Total : 3,057
