Aller au contenu principal
Disassembling Palm Zire 72v1
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. Disassembling Palm Zire 72v1, Zire 72v1: étape 1, image 1 de 1
    • Power off your Zire 72 and turn the unit over.
    • Remove the two screws on the bottom of the rear of the unit.
    • Peel back the information sticker.
    • Remove the one screw that connects the metal panel to the body of the Zire72.
    • Use the tip of your screwdriver to pop the metal panel off the top of the rear of the unit to expose two more screws on the top corners.
  2. Disassembling Palm Zire 72v1: étape 5, image 1 de 2 Disassembling Palm Zire 72v1: étape 5, image 2 de 2
    • Remove the two top screws.
    • Insert the tip of your screwdriver in the seam where the front frame meets the body of the unit and pry the frame up to pop it off. Remove it.
  3. Disassembling Palm Zire 72v1: étape 7, image 1 de 1
    • Pull the back panel off the body of the unit to expose the motherboard in the body.
    • Unplug the two orange ribbon cables at the top of the motherboard and remove the motherboard from the body. All that is left is the LCD screen in the front housing of the unit.
  4. Disassembling Palm Zire 72v1: étape 9, image 1 de 1
    • Remove the screen from the front housing and set it aside.
    • Now that you have your Zire open, you can remove and replace the defective part.
Lisa
Membre depuis le 09/08/11
13 Réputation
1 tutoriel rédigé
Équipe
University of Maine, Team 1-29, Diaz Fall 2011 Membre de l'équipe University of Maine, Team 1-29, Diaz Fall 2011
UMAINE-DIAZ-F11S1G29
2 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 107
