Aller au contenu principal
Panasonic KX-E603 Case Replacement
Ce dont vous avez besoin
  1. Panasonic KX-E603 Case Replacement, Case: étape 1, image 1 de 2 Panasonic KX-E603 Case Replacement, Case: étape 1, image 2 de 2
    • Flip the typewriter to expose the bottom body panel.
    • Be careful to not damage the top surface of the typewriter when you rest it upside-down.
  2. Panasonic KX-E603 Case Replacement: étape 2, image 1 de 1
    • Remove the three 19 mm screws located in the recessed holes on the edge of the black underside panel using a Phillips #2 screwdriver.
  3. Panasonic KX-E603 Case Replacement: étape 3, image 1 de 1
    • Flip the typewriter back to its original orientation, then rotate it so that the rear is facing towards you.
    • Remove the three 19 mm screws near the bottom of the tan body panel using a Phillips #2 screwdriver.
  4. Panasonic KX-E603 Case Replacement: étape 4, image 1 de 2 Panasonic KX-E603 Case Replacement: étape 4, image 2 de 2
    • Open the typewriter lid and push the carriage away to expose the two screws holding the case to the chassis.
    • Remove the two 19 mm screws using a Phillips #2 screwdriver.
  5. Panasonic KX-E603 Case Replacement: étape 5, image 1 de 2 Panasonic KX-E603 Case Replacement: étape 5, image 2 de 2
    • Flip the plastic lever on the right side of the roller wheel to disengage the paper lock.
  6. Panasonic KX-E603 Case Replacement: étape 6, image 1 de 3 Panasonic KX-E603 Case Replacement: étape 6, image 2 de 3 Panasonic KX-E603 Case Replacement: étape 6, image 3 de 3
    • Remove the roller wheel adjustment knobs by pulling firmly outward.
    • Both black knobs must be removed in this step.
  7. Panasonic KX-E603 Case Replacement: étape 7, image 1 de 2 Panasonic KX-E603 Case Replacement: étape 7, image 2 de 2
    • Unlock the roller wheel by simultaneously pressing down on the two spring levers on the left and right of the roller ends.
  8. Panasonic KX-E603 Case Replacement: étape 8, image 1 de 2 Panasonic KX-E603 Case Replacement: étape 8, image 2 de 2
    • While both spring levers are depressed, lift up with both hands to remove the roller wheel.
  9. Panasonic KX-E603 Case Replacement: étape 9, image 1 de 3 Panasonic KX-E603 Case Replacement: étape 9, image 2 de 3 Panasonic KX-E603 Case Replacement: étape 9, image 3 de 3
    • Flip the top down. Then, with both hands, lift straight up on the tan case to remove it from the chassis.
Matthew Callaghan
Membre depuis le 04/08/15
265 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 17-1, Forte Spring 2015 Membre de l'équipe Cal Poly, Team 17-1, Forte Spring 2015
CPSU-FORTE-S15S17G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 371
