Aller au contenu principal
Disassembling Pentax K200D Front Cover
Ce dont vous avez besoin
  1. Disassembling Pentax K200D Front Cover, Preparation: étape 1, image 1 de 1
    • Retrieve your Pentax K200D, the lens mount cover, and required tools.
    • Remove the lens, if you have one attached, and replace it with the lens mount cover to make handling and repair easier.
  2. Disassembling Pentax K200D Front Cover, Flash: étape 2, image 1 de 1
    • With the camera turned on, press the pop-up flash button to release the flash.
    • Be sure to turn the camera back off before proceeding.
    • Remove the two 4.3 mm Phillips screws securing the top edge of the front cover to the top cover.
  3. Disassembling Pentax K200D Front Cover, Bottom cover: étape 3, image 1 de 1
    • Remove the seven 4.3 mm Phillips screws securing the bottom cover to the camera body
    • Remove the two 2.5 mm Phillips screws also securing the bottom cover to the camera body
    • Open the battery door and carefully remove the bottom cover, as the battery door components become unsecured when the bottom cover is removed.
  4. Disassembling Pentax K200D Front Cover: étape 4, image 1 de 1
    • Remove the two 4.3 mm Phillips screws securing the right side of the front cover to the camera body.
9 autres ont terminé cette réparation.
Rick Nelson
Membre depuis le 06/05/10
706 Réputation
1 tutoriel rédigé
Équipe
Master Techs Membre de l'équipe Master Techs
Community
314 membres
1 319 tutoriels rédigés
Un commentaire
How do l clean the prisum…
brett_lorking - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 32
Total : 6,045
