Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Disassembling Philips wake up light HF3485 Diffuser
Ce dont vous avez besoin
    1. Disassembling Philips wake up light HF3485 Diffuser, Main board: étape 1, image 1 de 1
      • WARNING Make sure that the power cord of the lamp is unplugged and thus you will not encounter any live wire that tend to hurt...
      • Stand the lamp up on a table and slightly press on the top gray panel of the lamp.
      Demander à FixBot
      Ajouter un commentaire
    2. Disassembling Philips wake up light HF3485 Diffuser: étape 2, image 1 de 1
      • Turn the lid anticlockwise.
      • The top can now be easily removed.
      Demander à FixBot
    3. Disassembling Philips wake up light HF3485 Diffuser: étape 3, image 1 de 1
      • Take off the bulb from the socket.
      • By means of a long Philips screwdriver remove the 3 screws that holds the GU5.3 light bulb socket in place.
      Demander à FixBot
    4. Disassembling Philips wake up light HF3485 Diffuser: étape 4, image 1 de 1
      • Lay the lamp down on the table.
      • With a small flat screwdriver peel off the four rubber feet hiding screws of the lamp bottom panel.
      Demander à FixBot
    5. Disassembling Philips wake up light HF3485 Diffuser: étape 5, image 1 de 1
      • With a long Philips screwdriver remove the four screws from the deep holes of the bottom panel.
      Demander à FixBot
    6. Disassembling Philips wake up light HF3485 Diffuser: étape 6, image 1 de 1
      • With a small flat screwdriver remove the bottom trim by gently levering at the snaps joining it with the command unit.
      Demander à FixBot
    7. Disassembling Philips wake up light HF3485 Diffuser: étape 7, image 1 de 1
      • Carefully remove the bottom trim.
      Demander à FixBot
    8. Disassembling Philips wake up light HF3485 Diffuser: étape 8, image 1 de 1
      • Locate the 8 plastic snap-ins that hold the diffuser attached to the bottom board of the lamp.
      • These snap-ins are strongly attaching the diffuse to the bottom board and we may have to break one or two of them in order to separate the diffuser.
      Demander à FixBot
    9. Disassembling Philips wake up light HF3485 Diffuser: étape 9, image 1 de 1
      • Cut one or two plastic snap-ins with a box-cutter.
      • This will ease to free the other plastic snap-ins without any other risk of damage. Philips must have designed this so that the lamp can not be serviced.
      Demander à FixBot
    10. Disassembling Philips wake up light HF3485 Diffuser: étape 10, image 1 de 1
      • With a small straight screwdriver free the remaining 6 snaps by simultaneously press each snap and pull the diffuser off the bottom board.
      Demander à FixBot
    11. Disassembling Philips wake up light HF3485 Diffuser: étape 11, image 1 de 1
      • Smoothly pull off the main board from the diffuser.
      • On the figure note the snap-ins in green that remain intact from the previous step and the snap-in in orange that was cut.
      Demander à FixBot
    12. Disassembling Philips wake up light HF3485 Diffuser: étape 12, image 1 de 1
      • With a pair of scissors cut the plastic clip fastener that ties the two wires of the bulb socket.
      • This step is necessary to loose the main board.
      Demander à FixBot
    13. Disassembling Philips wake up light HF3485 Diffuser: étape 13, image 1 de 1
      • Now we can go ahead with the fixing of the electronic board.
      Demander à FixBot
22 autres ont terminé cette réparation.
David
Membre depuis le 05/23/14
1 661 Réputation
5 tutoriels rédigés
13 commentaires de tutoriel
I would suggest following the steps in a different order:
remove bottom trim
remove diffuser
then remove the bulb & socket, and the 4 screws from the bottom which will allow access to the main board.
Alex - Réponse Partager
Hi,
The guide was very helpful as I just received such lamp for checking from one friend.
I would make only make one correction: you do not have to cut the plastic snap-ins, none of them.
If you use an IPhone opening toll kit, with those plastic levers as here:
[produit lié absent ou désactivé : IF145-000]
then you can open it easy, without any scratches.
Victor - Réponse Partager
Excellent guide. I did, however, not have to cut off any off the plastic snap-ins from step 9. Used a bigger screwdriver and gently used a bit of force, and one-by-one they came off.
kostermw - Réponse Partager
im wondering whether its possible to overwrite the wake sounds...
Chris Mair - Réponse Partager
Thank you so much for this guide. Was just about to give up on my lamp and buy and inferior led version when I found this.
These steps also work for the 3740 but the tabs holding the shade on (steps 8-10) are a different style. More like the ones on the bottom trim piece. Had to really work them and muscle that part off.
My ceramic bulb holder is severely corroded to the point where the light will only turn on if you jiggle the bulb. A little sad to see that the wires going to it are permanently attached on both ends. Now that the whole thing is apart. I'm going to see if I can source a new bulb holder and splice it onto the top...
Griffin - Réponse Partager
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 39
30 derniers jours : 102
Total : 16,227
