Aller au contenu principal
Disassembling RCA CC310 Left Cover
Ce dont vous avez besoin
  1. Disassembling RCA CC310 Left Cover, Disassembling RCA CC310 Left Cover: étape 1, image 1 de 2 Disassembling RCA CC310 Left Cover, Disassembling RCA CC310 Left Cover: étape 1, image 2 de 2
    • Remove the six 7.9mm Phillips #0 screws on the back and bottom.
    • Remove the one 3.8mm Phillips #0 screw on the bottom.
    • Remove the two 7.5mm Phillips #0 screws on the back and bottom.
  2. Disassembling RCA CC310 Left Cover: étape 2, image 1 de 2 Disassembling RCA CC310 Left Cover: étape 2, image 2 de 2
    • Remove 5.8mm Phillips #1 screw from the side button panel.
    • Slide the viewfinder all the way to the right and remove the 7.9mm Phillips #0 screw.
  3. Disassembling RCA CC310 Left Cover: étape 3, image 1 de 2 Disassembling RCA CC310 Left Cover: étape 3, image 2 de 2
    • Pry along the seam on the top side near the buttons with a spudger.
  4. Disassembling RCA CC310 Left Cover: étape 4, image 1 de 2 Disassembling RCA CC310 Left Cover: étape 4, image 2 de 2
    • Pull the left panel away from the rest of the camcorder.
    • Unplug the red speaker cable located at the rear of the device.
    • Be careful to not pull too hard. The speaker cable is still connected to the panel and it can rip.
Ashley Katchadourian
Membre depuis le 01/20/11
133 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 5-20, Amido Winter 2011 Membre de l'équipe Cal Poly, Team 5-20, Amido Winter 2011
CPSU-AMIDO-W11S5G20
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 11
Total : 950
