Aller au contenu principal
Disassembling Samsung Galaxy Ace Logic Board
Ce dont vous avez besoin
  1. Disassembling Samsung Galaxy Ace Logic Board, Logic Board: étape 1, image 1 de 2 Disassembling Samsung Galaxy Ace Logic Board, Logic Board: étape 1, image 2 de 2
    • Remove the battery cover and the battery
  2. Disassembling Samsung Galaxy Ace Logic Board: étape 2, image 1 de 2 Disassembling Samsung Galaxy Ace Logic Board: étape 2, image 2 de 2
    • Remove the 7 silver screws with a Phillips #000 screw driver.
    • Sometimes the green one could be a little difficult. Use a tweezer for get it out.
  3. Disassembling Samsung Galaxy Ace Logic Board: étape 3, image 1 de 3 Disassembling Samsung Galaxy Ace Logic Board: étape 3, image 2 de 3 Disassembling Samsung Galaxy Ace Logic Board: étape 3, image 3 de 3
    • Lift gently the back cover from the screen assembly from the bottom.
  4. Disassembling Samsung Galaxy Ace Logic Board: étape 4, image 1 de 2 Disassembling Samsung Galaxy Ace Logic Board: étape 4, image 2 de 2
    • Use a flat tweezer for take off the flexible on/off button from the frame.
    • Be careful, the flexible is very delicate; it could be cut if you go too fast.
  5. Disassembling Samsung Galaxy Ace Logic Board: étape 5, image 1 de 3 Disassembling Samsung Galaxy Ace Logic Board: étape 5, image 2 de 3 Disassembling Samsung Galaxy Ace Logic Board: étape 5, image 3 de 3
    • Use a flat tweezer and take off gently Flexible volume button from the left side.
    • Do the same for the right side.
    • Then lift the flex slowly, if you go fast you may cut the cable.
  6. Disassembling Samsung Galaxy Ace Logic Board: étape 6, image 1 de 1
    • Lift the microphone from the logic board.
  7. Disassembling Samsung Galaxy Ace Logic Board: étape 7, image 1 de 3 Disassembling Samsung Galaxy Ace Logic Board: étape 7, image 2 de 3 Disassembling Samsung Galaxy Ace Logic Board: étape 7, image 3 de 3
    • Lift the sensor/earpiece cable with the opening tool.
    • Don't force, you may damage the soldering.
  8. Disassembling Samsung Galaxy Ace Logic Board: étape 8, image 1 de 3 Disassembling Samsung Galaxy Ace Logic Board: étape 8, image 2 de 3 Disassembling Samsung Galaxy Ace Logic Board: étape 8, image 3 de 3
    • Lift the logic board from the right side.
    • Use the removal tool to unplug the display cable from the logic board.
    • You can now separate the Logic board from the display assembly.
  9. Disassembling Samsung Galaxy Ace Logic Board: étape 9, image 1 de 2 Disassembling Samsung Galaxy Ace Logic Board: étape 9, image 2 de 2
    • Use the removal tool to unclip the camera module from the Logic board.
  10. Disassembling Samsung Galaxy Ace Logic Board: étape 10, image 1 de 3 Disassembling Samsung Galaxy Ace Logic Board: étape 10, image 2 de 3 Disassembling Samsung Galaxy Ace Logic Board: étape 10, image 3 de 3
    • Use the removal tool or a spudger to unplug speaker module cable
    • And separate the speaker module from Logic board.
    • Be caution, the module is fixed by plastic teeth to the Logic board. Don't force, just make little wave-movements and the speaker comes on his own.
  11. Disassembling Samsung Galaxy Ace Logic Board: étape 11, image 1 de 1
    • Now you can work with the Logic board.
34 autres ont terminé cette réparation.
finster
Membre depuis le 08/17/11
1 986 Réputation
1 tutoriel rédigé
2 commentaires
Thanks for the post. This is really Helpful
Dave Dayanan - Réponse
im curently selling one thx to you
Kyle at work - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 13
Total : 26,699
