This guide allows users of the Samsung Galaxy S Blaze to take the phone apart. You will need to be careful with the screws that are inside the device, the screws will strip easily. To properly disassemble the phone you will need a Phillips Head screw driver size 00 and a flat wedge opening device.
Use a Phillips head screwdriver size 00.
Remove the 4mm screws from the frame.
The eight screws are all the same size.
Remove the frame from the phone by using the blue plastic opening tool.
Work around the phone with the tool until the frame is off.
You may need to use a bit of force to pry off the frame.
The SD card slot is held in place by a small tab.
Unhook the tab of the SD card slot, from the frame of the phone.
4 ribbon cable connectors hold the motherboard to the phone.
The first 3 are all on one side.
Use the blue plastic opening tool to unlatch the wire ribbons from the motherboard.
Flip the motherboard over to access the last ribbon cable connector.
Unlatch the final ribbon cable connector from the phone.
Remove the motherboard from the phone.
Intégrer ce tutoriel
Choisissez une taille et copiez le code ci-dessous pour intégrer ce tutoriel sous la forme d'un petit widget sur votre site / forum.
Étape unique
Tutoriel complet
Petit - 600 px
Moyen - 800 px
Grand - 1200 px
Aperçu
