Introduction
This guide will walk you through how to disassemble the Samsung Gear 2.
Outils
Pièces
Aucune pièce spécifiée.
To remove each strap, locate the metal latches on both sides of the back of the Gear.
Press down on the metal latch while pulling the strap away from the Gear until it is completely off.
Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components.
Pry the device open from the other side also if it does not fully disassemble from one side.
4 autre(s) ont terminé cette réparation.
