Aller au contenu principal
Fix Your Stuff
Right to Repair
Parts & Tools
Pièces
Aucune pièce spécifiée.
  1. Remove the 8 small screws.
    • Remove the 8 small screws.
  2. Remove the other 6 screws. Hard disk.
    • Remove the other 6 screws.
    • Hard disk.
    • RAM slots.
  3. Hard disk - Hitachi 500 GB
    • Hard disk - Hitachi 500 GB
  4. The hard disk should have been taken out before this step.
    • The hard disk should have been taken out before this step.
    • Carefully detach the bottom cover.
  5. Bottom cover removed
    • Bottom cover removed
  6. Remove the 4 screws to detach the battery.
    • Remove the 4 screws to detach the battery.
    • Remove all the sticky tape.
    • Carefully disconnect the small power connector by using a tool to push the connector out through the small gap mid-connector. It won't come out all the way, because the battery pack is in its way.
  7. Samsung 7.4V 45Wh battery. Samsung 7.4V 45Wh battery.
    • Samsung 7.4V 45Wh battery.
  8. Battery removed.
    • Battery removed.
  9. Remove Fan with Processor heat sink.
    • Remove Fan with Processor heat sink.
    • ( 2 screws)
  10. Remove Fan with Processor heat sink.
    • (3 screws)
  11. Disconnect antenna cables from WiFi card.
    • Disconnect antenna cables from WiFi card.
    • Remove the screw.
    • Be sure to match the colors when reattaching the cables.
  12. Remove this screw.
    • Remove this screw.
    • Uplift the latch to loose the cable.
  13. Remove this screw.
  14. Remove this screw.
  15. To remove Motherboard, carefully disconnect the cables.
    • To remove Motherboard, carefully disconnect the cables.
  16. Motherboard - front and rear Motherboard - front and rear
    • Motherboard - front and rear
  17. Processor fan.
    • Processor fan.
30 autre(s) ont terminé cette réparation.
Jose Gustavo Abreu Murta
Membre depuis le 06/07/2010
2 583 Réputation
7 tutoriels rédigés
29 commentaires
Hello,
Do you know where can i reset the Bios CMOS in that motherboard?
I think there are people who wants to know becose system upgrade is leading to bios ACPI Error.
Thanks for your help
Luis Orland - Réponse
No, I do not know where is a reset pin of BIOS.
Try to disconnect NVRAM battery.
Wait 15 minutes and reconnect again.
Jose Gustavo Abreu Murta - Réponse
To reset BIOS this NP530U3, only disconnect all power supply (MAIN battery, CMOS battery and power source). And hold press POWER button for 1 min.
warmdk - Réponse
I try it but don't work, do you know another way to do this
manhique -
Hello,
I have seen many screens with model number LTN140AT21-XXX for this laptop. My laptop NP530u4b has a screen LTN140AT21-802. I would like to know if I can use a LTN140AT21-002 screen, or if only is good a screen with number LTN140AT21-8.
thanks for your help.
alex - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 7
7 derniers jours : 37
30 derniers jours : 170
Total : 46,473
