Aller au contenu principal
  1. Remove the batteries, memory card, and wrist strap if so equipped. Remove the four screws on the bottom. Remove the two screws on the right hand side
    • Remove the batteries, memory card, and wrist strap if so equipped.
    • Remove the four screws on the bottom.
    • Remove the two screws on the right hand side
  2. Remove the two screws from the left hand side The screws are identical in length. No reason to keep them separate Split the case from the battery compartment down. You can use an opening tool or your fingernails to accomplish that.
    • Remove the two screws from the left hand side
    • The screws are identical in length. No reason to keep them separate
    • Split the case from the battery compartment down. You can use an opening tool or your fingernails to accomplish that.
  3. Fix Kits pour batterie de MacBook
    À partir de $69.99
    Buy Now
    À partir de $69.99
    Buy Now
  4. With the case split, you can see the LCD in its holder. The LCD is simply laid into the holder. Gently remove the LCD from the holder and just flip it to the side. Do not remove it yet. You will have to loosen the clip on the connector. Use your fingernails to move it in the opposite direction from the LCD, this will open it up. Remove the four screws from the LCD holder.
    • With the case split, you can see the LCD in its holder. The LCD is simply laid into the holder.
    • Gently remove the LCD from the holder and just flip it to the side. Do not remove it yet. You will have to loosen the clip on the connector. Use your fingernails to move it in the opposite direction from the LCD, this will open it up.
    • Remove the four screws from the LCD holder.
  5. LCD holder removed from logic board disconnect the ribbon cable from the logic board. This one requires to move the brown tabs on the left and right hands side in an upward direction. They should just slide up by about an 1/8th of an inch. this will free the ribbon cable. With the ribbon cable disconnected, remove the front case.
    • LCD holder removed from logic board
    • disconnect the ribbon cable from the logic board. This one requires to move the brown tabs on the left and right hands side in an upward direction. They should just slide up by about an 1/8th of an inch. this will free the ribbon cable.
    • With the ribbon cable disconnected, remove the front case.
  6. Remove the CCD and the lens ribbon cable from the connectors. To release the CCD cable, gently slide the brown clips on either side to the left. This will release the cable. Desolder the connector from the top PCB. Use a soldering wick and flux to make the task easier.
    • Remove the CCD and the lens ribbon cable from the connectors.
    • To release the CCD cable, gently slide the brown clips on either side to the left. This will release the cable.
    • Desolder the connector from the top PCB. Use a soldering wick and flux to make the task easier.
  7. Desolder the battery connectors. Desolder the black and red wire. Remove the logic board from the midframe.
    • Desolder the battery connectors.
    • Desolder the black and red wire.
    • Remove the logic board from the midframe.
2 autre(s) ont terminé cette réparation.
oldturkey03
Membre depuis le 29/09/2010
592 263 Réputation
102 tutoriels rédigés
Équipe
OTS Membre de l'équipe OTS
Business
1 membre
129 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 1,024
