Pièces
Aucune pièce nécessaire.
Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
  • Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
Ajouter un commentaire
Remove the screw on each side of the device using a Phillips head screwdriver.
  • Remove the screw on each side of the device using a Phillips head screwdriver.
  • Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws.
  • Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
  • Using the philips screwdriver, remove the two screws on the mother board.
  • Place the pry tool in-between the front cover and mother board.
  • Gently separate the front cover.
  • After opening the front cover you will see and electric ribbon connecting the buttons to the mother board.
  • CAUTION: Do not rip the electric ribbon from the mother board.
  • Carefully flip up the plastic lip that holds the electric ribbon to the board.
Jason Farr
Membre depuis le 21/10/2013
337 Réputation
3 tutoriels rédigés
Équipe
Clemson, Team 14-8, Benson Fall 2013 Membre de l'équipe Clemson, Team 14-8, Benson Fall 2013
CLEM-BENSON-F13S14G8
3 membres
7 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 140
