Aller au contenu principal
Disassembling Sanyo VPC-T850 Outer Casing
Ce dont vous avez besoin
  1. Disassembling Sanyo VPC-T850 Outer Casing, Disassembling Sanyo VPC-T850 Outer Casing: étape 1, image 1 de 1
    • Turn the camera off by pressing the small, square button embedded in the top rim of the camera.
    • Locate the battery hatch on the bottom-right side of the camera and slide it outwards to open.
    • In the compartment, move the small notch and push down on the battery to remove it.
    • During reassembly, there is an arrow on the battery hatch indicating which way it goes in.
  2. Disassembling Sanyo VPC-T850 Outer Casing, Remove Screws: étape 2, image 1 de 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Screws: étape 2, image 2 de 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Screws: étape 2, image 3 de 3
    • Remove the eight screws around the sides and bottom of the camera using a Phillips #00 screwdriver.
  3. Disassembling Sanyo VPC-T850 Outer Casing, Remove Rear Panel: étape 3, image 1 de 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Rear Panel: étape 3, image 2 de 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Rear Panel: étape 3, image 3 de 3
    • Using the spudger, gently pry the rear panel away from the left side.
    • Be careful not to damage the three green cables as you remove the rear panel of the camera.
  4. Disassembling Sanyo VPC-T850 Outer Casing: étape 4, image 1 de 1
    • Using the Phillips #00 screwdriver, remove the eight black screws connecting the green keypad chip to the rear panel.
    • Do not put any excessive force on the green wires.
  5. Disassembling Sanyo VPC-T850 Outer Casing: étape 5, image 1 de 1
    • Separate the rear panel from the rest of the camera.
  6. Disassembling Sanyo VPC-T850 Outer Casing: étape 6, image 1 de 2 Disassembling Sanyo VPC-T850 Outer Casing: étape 6, image 2 de 2
    • Using the Phillips #00 screwdriver, remove the 3 screws located across the top of the camera.
    • Separate the black plastic panel from the camera. The camera button will be attached, so be gentle.
  7. Disassembling Sanyo VPC-T850 Outer Casing: étape 7, image 1 de 2 Disassembling Sanyo VPC-T850 Outer Casing: étape 7, image 2 de 2
    • Carefully pull off the side covers wrapped around the camera.
  8. Disassembling Sanyo VPC-T850 Outer Casing, Remove Front Cover: étape 8, image 1 de 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Front Cover: étape 8, image 2 de 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Front Cover: étape 8, image 3 de 3
    • Using the spudger, gently lift off the front cover of the camera.
    • The front cover is fragile, so be gentle when removing it. It can easily break if not removed carefully.
Jonathan Yau
Membre depuis le 04/11/10
26 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 27-95, Amido Spring 2010 Membre de l'équipe Cal Poly, Team 27-95, Amido Spring 2010
CPSU-AMIDO-S10S27G95
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 10
Total : 2,063
