Introduction
This guide will show you how to open the radio casing to diagnose internal issues and check internal connections.
Ce dont vous avez besoin
Press down on the two tabs at the top of the door.
Rotate the door away from the radio, towards you.
Lift the door out of the three smaller tabs on the bottom.
Push the batteries against the spring and pull out using your finger to remove them.
Remove the 6 screws (30 mm in length) with the Phillips #2 Screwdriver from the large holes marked by arrows on the radio.
4 autres ont terminé cette réparation.
