Aller au contenu principal
Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly
Ce dont vous avez besoin
  1. Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly, Main Speaker Housing Disassembly: étape 1, image 1 de 1
    • Remove two 6mm Phillips #0 screws.
    • Remove two 7.5 mm Phillips #0 screws.
    • Remove seven 4 mm Phillips #0 screws.
  2. Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly: étape 2, image 1 de 3 Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly: étape 2, image 2 de 3 Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly: étape 2, image 3 de 3
    • Remove six 4 mm Phillips #0 screws from the metal backing.
    • Remove six 5 mm Phillips #0 screws from the metal backing.
    • Using the plastic opening tool, remove the metal plate from the main speaker by gently pulling on it.
  3. Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly: étape 3, image 1 de 2 Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly: étape 3, image 2 de 2
    • Remove the plastic dock cover by using two fingers to push the attached metal piece forward and slide it out of the holes.
  4. Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly: étape 4, image 1 de 3 Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly: étape 4, image 2 de 3 Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    • Using the plastic opening tool, detach the wires connected to the metal plate
    • When disconnecting the wires, be careful not to pull on the wires themselves. Use the plastic opening tool and the connector to disconnect it.
    • Use the plastic opening tool to remove wires connected to the circuit board on the far right.
    • Use the tweezers to remove wires connected to the circuit board in between the two black wires.
    • Use the tweezers to press the release tab on the front and back of the plastic white wire head.
    • Once the tab is pressed on both sides, lift up to slide wire head out of socket.
  5. Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly: étape 5, image 1 de 1
    • Remove two 5 mm Phillips #0 screws.
  6. Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly: étape 6, image 1 de 3 Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly: étape 6, image 2 de 3 Disassembling Sony CPF-IP001 Main Speaker Housing Disassembly: étape 6, image 3 de 3
    • Using the metal spudger, loosen the metal cap at the end of the speaker.
    • Slide down the loosened cap to remove it from the end of the speaker.
    • Simultaneously push down on the buttons and slide the speaker out from the casing.
Marlena Perez
Membre depuis le 04/14/15
442 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 6-14, Maness Spring 2015 Membre de l'équipe Cal Poly, Team 6-14, Maness Spring 2015
CPSU-MANESS-S15S6G14
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 825
