Aller au contenu principal
Disassembling Sony Cyber-shot DSC-W230 Removing the Camera Sensor
Ce dont vous avez besoin
  1. Disassembling Sony Cyber-shot DSC-W230 Removing the Camera Sensor, Case: étape 1, image 1 de 1
    • Begin by placing the camera upside down and removing the three small center screws.
    • All screws are the same size and length and can be used interchangably.
  2. Disassembling Sony Cyber-shot DSC-W230 Removing the Camera Sensor: étape 2, image 1 de 2 Disassembling Sony Cyber-shot DSC-W230 Removing the Camera Sensor: étape 2, image 2 de 2
    • Turn the camera on its side (Counterclockwise). Remove the two small screws on either side of the silver panel.
    • Turn the camera 180 degrees onto its other side and remove the two small screws on either side of the silver panel.
  3. Disassembling Sony Cyber-shot DSC-W230 Removing the Camera Sensor: étape 3, image 1 de 3 Disassembling Sony Cyber-shot DSC-W230 Removing the Camera Sensor: étape 3, image 2 de 3 Disassembling Sony Cyber-shot DSC-W230 Removing the Camera Sensor: étape 3, image 3 de 3
    • Locate the camera's tripod mount located on the bottom of the camera.
    • Carefully remove the camera's tripod mount and place it aside.
    • Be careful not to lose this piece.
    • Rotate the silver panel labeled 4x clockwise.
  4. Disassembling Sony Cyber-shot DSC-W230 Removing the Camera Sensor, Separating Camera and Display: étape 4, image 1 de 2 Disassembling Sony Cyber-shot DSC-W230 Removing the Camera Sensor, Separating Camera and Display: étape 4, image 2 de 2
    • Align the camera so that the side with "4x Optical Zoom" is facing toward you.
    • Gently twist the bottom corner clockwise until you feel the side panel unlock.
    • Lift off the side panel and set aside.
  5. Disassembling Sony Cyber-shot DSC-W230 Removing the Camera Sensor: étape 5, image 1 de 2 Disassembling Sony Cyber-shot DSC-W230 Removing the Camera Sensor: étape 5, image 2 de 2
    • Rotate the camera 180 degrees to face the side panel with the lanyard loop on it.
    • Gently lift the panel vertically until it lifts off
    • Take care to not lose the small rectangular portion on the bottom of the panel.
  6. Disassembling Sony Cyber-shot DSC-W230 Removing the Camera Sensor: étape 6, image 1 de 3 Disassembling Sony Cyber-shot DSC-W230 Removing the Camera Sensor: étape 6, image 2 de 3 Disassembling Sony Cyber-shot DSC-W230 Removing the Camera Sensor: étape 6, image 3 de 3
    • Position the camera so the bottom is facing up and the display away from the surface.
    • Gently pry the screen portion from the camera portion with your fingers or a plastic prybar.
    • Do not fully separate the two components! the screen is attached by two ribbon cables.
    • Lay the display flat to expose the circuit board and the display control ribbon cables.
  7. Disassembling Sony Cyber-shot DSC-W230 Removing the Camera Sensor, LCD Display Screen: étape 7, image 1 de 1
    • Using a flat head screw driver gently pry up the tab securing the ribbon cable from the display screen to the camera sensor and battery housing.
    • Remove the ribbon cable connecting LCD display to camera sensor and battery housing
    • Following the same procedure as above, uninstall the ribbon cable connecting the main camera controls to the camera sensor and battery housing
  8. Disassembling Sony Cyber-shot DSC-W230 Removing the Camera Sensor: étape 8, image 1 de 1
    • The LCD display screen is now removed from the camera sensor and battery housing.
    • The main camera controls are now removed from the camera sensor and battery housing.
  9. Disassembling Sony Cyber-shot DSC-W230 Removing the Camera Sensor: étape 9, image 1 de 1
    • Unsnap LCD display screen from its mount by unsnapping it from the display screen using your finger nail.
    • Now the new LCD screen can be installed.
  10. Disassembling Sony Cyber-shot DSC-W230 Removing the Camera Sensor, Ribbon Cable: étape 10, image 1 de 1
    • Using a flat head screw driver gently pry up on the tab securing the larger ribbon cable which connects the display screen and camera sensor / battery housing.
    • Remove the ribbon cable connecting the LCD display and camera sensor / battery housing.
    • Following the same procedure, uninstall the ribbon cable connecting the main camera controls to the camera sensor and battery housing
  11. Disassembling Sony Cyber-shot DSC-W230 Removing the Camera Sensor: étape 11, image 1 de 3 Disassembling Sony Cyber-shot DSC-W230 Removing the Camera Sensor: étape 11, image 2 de 3 Disassembling Sony Cyber-shot DSC-W230 Removing the Camera Sensor: étape 11, image 3 de 3
    • Now turn your attention to the camera sensor and battery housing. Identify the two connection points of the large ribbon cable.
    • Carefully place a flathead screwdriver under the left ribbon cable connection point and pull up to disconnect.
    • Repeat the previous step but this time carefully remove the right ribbon cable connection point.
    • After both sides of the ribbon cable have been disconnected it is ready to be replaced.
  12. Disassembling Sony Cyber-shot DSC-W230 Removing the Camera Sensor, Disassembling Sony Cyber-shot DSC-W230 Removing the Camera Sensor: étape 12, image 1 de 2 Disassembling Sony Cyber-shot DSC-W230 Removing the Camera Sensor, Disassembling Sony Cyber-shot DSC-W230 Removing the Camera Sensor: étape 12, image 2 de 2
    • After removal of the LCD screen and ribbon cable the camera sensor can be accessed.
    • Position the camera with the circuit board facing up, showing the two ribbon cables connecting the camera sensor.
    • Gently pry the black tabs on both cables until they are flipped up.
    • Gently pull the ribbon cables until they slide out of the connectors.
  13. Disassembling Sony Cyber-shot DSC-W230 Removing the Camera Sensor: étape 13, image 1 de 3 Disassembling Sony Cyber-shot DSC-W230 Removing the Camera Sensor: étape 13, image 2 de 3 Disassembling Sony Cyber-shot DSC-W230 Removing the Camera Sensor: étape 13, image 3 de 3
    • Flip the camera over so the shutter is facing up and the top buttons are away from you.
    • Making sure the ribbon cables are free, lift the battery housing up while keeping the camera sensor on the table, this will flip it up and provide access to the shutter button cable.
    • Gently slide out the cable to free the camera sensor from the rest of the housing.
Steve Van Hall
Membre depuis le 03/09/12
27 Réputation
2 tutoriels rédigés
Équipe
Clemson, Team 2-3, Benson Spring 2012 Membre de l'équipe Clemson, Team 2-3, Benson Spring 2012
CLEM-BENSON-S12S2G3
3 membres
11 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 2,340
