Introduction
Removing the core is easy, but you will be removing 4 screws, so make sure you have a place to put them for safe-keeping.
Ce dont vous avez besoin
Slide the battery cover up and off the phone.
Insert the plastic opening tool in between the front case and the back case.
Apply downward pressure to make the case lift upwards, thus popping the front case off.
Remove the 4 screws in the corners of the front of the phone using a T6 screwdriver.
